AlienBZ Posted January 24, 2013 Share Posted January 24, 2013 I've modeled so far what looks to me the church where I got saved, that is this church for my movie (top photo). and as you see, this church has a diagonal roof (pitched roof) so I did this (bottom photo) to try to make the triangle boxes for the pitched roof. I have no problem adding up/down, L/R segments to my boxes but how do I add diagonal segments? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted January 24, 2013 Share Posted January 24, 2013 how do I add diagonal segments? You don't. Watch these videos: Quote Link to comment Share on other sites More sharing options...
AlienBZ Posted January 25, 2013 Author Share Posted January 25, 2013 Ok, I did this to the roof faces, but i made these diagonal lines in only one direction, yet five minutes ago when I tried to follow that video after I made a flat box resting on the floor of the church I accidentally created the diagonal lines (I think they're segments) going in both directions, but it was trial and error and I don't remember hoiw exactly I did that. How does anyone know how I created these bi-directional diagonal lines five minutes ago? stumped. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted January 25, 2013 Share Posted January 25, 2013 First of all, why do you insist on using that "Edit Patch" modifier? Get rid of it. You do not need it. All you're doing is making things more complicated than they need to be. In fact, that modifier may be what's causing the diagonals. I would suggest that you delete the modifier, delete the object and make a new one. And stop using that modifier. Quote Link to comment Share on other sites More sharing options...
AlienBZ Posted January 25, 2013 Author Share Posted January 25, 2013 First of all, why do you insist on using that "Edit Patch" modifier? Get rid of it. You do not need it. All you're doing is making things more complicated than they need to be. In fact, that modifier may be what's causing the diagonals. I would suggest that you delete the modifier, delete the object and make a new one. And stop using that modifier. I wanted to create these diagonals so I could go to face/element select, select a triangular outline on that object (faces of object/box that connect the building with the roof surfaces) and then delete them so as to have a triangular shaped box on which the roof objects will sit on top as 2 boxes on each side of the roof pitch). I used that edit patch editor b/c I was trying to follow that video on how to make the pitched roof. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted January 25, 2013 Share Posted January 25, 2013 I used that edit patch editor b/c I was trying to follow that video on how to make the pitched roof. I just watched that video and I did not see him use an edit patch modifier to create the roof. Quote Link to comment Share on other sites More sharing options...
