Hi ,
I just started a new job and they use Autocad Electrical 2013. I'm having problem with getting for an example 74 pages of a electrical plan in one PDF document. I look on the internet and try the way I saw. So I follow those instruction :
. It works for only one of my project and when I came to use it for an another it dosent work anymore. I have an error when I began to publish . The error say :
Job: - Plotted with Errors(s)
Job ID: 1
Sheet set name:
Date and time started: 1/24/2013 7:23:40 AM
Date and time completed: 1/24/2013 7:23:43 AM
UserID: CAJETET1
Profile ID: >
Total sheets: 2
Sheets plotted: 1
Number of errors: 1
Number of warnings: 0
ERROR: Error saving PDF file; PDF file is open or uneditable.
CHECK.GIF[/url]Sheet: A03B00201-1- NAMEPLATES - Plotted
File: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Category name:
Page setup: A3
Device name: DWG To PDF.pc3 - plotted to file
Plot file path: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Paper size: ISO full bleed A3 (297.00 x 420.00 MM)
ERROR.GIFSheet: A03B00201-2- CSA NAMEPLATE - Error(s) Did Not Plot
Category name:
Page setup: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx.dwg A3
Plot file path: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
ERROR: Page setup properties error. The page setup may be corrupted.
Thanks alot ! Sorry for my english i'm from Quebec,Canada!
I think I've fix a part of my problem but , when i open my PDF document one my drawing have the page setup that I give but the rest dosent have the good scale.
