woodman78 Posted January 24, 2013 Posted January 24, 2013 I have a layout that we use for land maps for our mapping authority. I need to indicate the coords of the extent of the viewport but the coords need to be from the model space. I was thinking of writing a lisp that would draw a rectang over the viewport, create a selection set with the rectang, move it to the model tab and then query the coords of the corners and input them into the fields. Then if the view is changed the routine would delete the layer with the rectang on it and start the process again. Is this way over the top? Is there another way to do this? Thanks. Quote
Lee Mac Posted January 24, 2013 Posted January 24, 2013 Try the following quick program: ([color=BLUE]defun[/color] c:vprec ( [color=BLUE]/[/color] _text l j k p ) ([color=BLUE]defun[/color] _text ( s p r j ) ([color=BLUE]entmake[/color] ([color=BLUE]list[/color] '(0 . [color=MAROON]"TEXT"[/color]) ([color=BLUE]cons[/color] 410 ([color=BLUE]getvar[/color] 'ctab)) ([color=BLUE]cons[/color] 040 ([color=BLUE]getvar[/color] 'textsize)) ([color=BLUE]cons[/color] 007 ([color=BLUE]getvar[/color] 'textstyle)) ([color=BLUE]cons[/color] 010 p) ([color=BLUE]cons[/color] 011 p) ([color=BLUE]cons[/color] 001 s) ([color=BLUE]cons[/color] 050 r) ([color=BLUE]cons[/color] 072 j) '(73 . 2) ) ) ) ([color=BLUE]cond[/color] ( ([color=BLUE]=[/color] 1 ([color=BLUE]getvar[/color] 'tilemode)) ([color=BLUE]princ[/color] [color=MAROON]"\nCommand only available in Paperspace."[/color]) ) ( ([color=BLUE]=[/color] 1 ([color=BLUE]getvar[/color] 'cvport)) ([color=BLUE]princ[/color] [color=MAROON]"\nPlease activate a viewport."[/color]) ) ( ([color=BLUE]setq[/color] l ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] ([color=BLUE]getvar[/color] 'cvport) ([color=BLUE]vports[/color]))) j '(2 0 2 0) k '(2 0 0 2) ) ([color=BLUE]foreach[/color] x ([color=BLUE]list[/color] ([color=BLUE]car[/color] l) ([color=BLUE]cadr[/color] l) ([color=BLUE]list[/color] ([color=BLUE]caadr[/color] l) ([color=BLUE]cadar[/color] l)) ([color=BLUE]list[/color] ([color=BLUE]caar[/color] l) ([color=BLUE]cadadr[/color] l))) ([color=BLUE]setq[/color] p ([color=BLUE]mapcar[/color] '[color=BLUE]rtos[/color] ([color=BLUE]trans[/color] ([color=BLUE]trans[/color] x 3 2) 2 0))) (_text ([color=BLUE]strcat[/color] [color=MAROON]"E:"[/color] ([color=BLUE]car[/color] p)) x ([color=BLUE]/[/color] [color=BLUE]pi[/color] 2.0) ([color=BLUE]car[/color] j)) (_text ([color=BLUE]strcat[/color] [color=MAROON]"N:"[/color] ([color=BLUE]cadr[/color] p)) x 0.0 ([color=BLUE]car[/color] k)) ([color=BLUE]setq[/color] j ([color=BLUE]cdr[/color] j) k ([color=BLUE]cdr[/color] k) ) ) ) ) ([color=BLUE]princ[/color]) ) Quote
woodman78 Posted January 25, 2013 Author Posted January 25, 2013 Thanks LeeMac. That is excellent. There are 2 issues though. The first is that if I run it more than once it overwrites the first text. The second is the text height. I have tried to create a text style for this and set the height in that to 5 but the text keeps coming in at 2.5 even though the new style is set to current. What am I missing with this? Thanks again... Quote
woodman78 Posted January 25, 2013 Author Posted January 25, 2013 LeeMac, Just found the solution to the text height issue. Thanks. Quote
Lee Mac Posted January 25, 2013 Posted January 25, 2013 The first is that if I run it more than once it overwrites the first text. Of course, it just creates the text. The second is the text height. I have tried to create a text style for this and set the height in that to 5 but the text keeps coming in at 2.5 even though the new style is set to current. What am I missing with this? The text height is sourced from the TEXTSIZE System Variable. Quote
woodman78 Posted January 25, 2013 Author Posted January 25, 2013 Thanks LeeMac, I got sorted on the text height and on the issue of overwriting. One other thing I forgot to ask and that is how I can limit the numbers to whole numbers without and decimal places.. http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Rounding-Text-to-Less-Decimal-Places/td-p/2510232 As per this link the setting in your program seems to be set to 0 but it still gives 4 places of decimals....Am I reading this wrong? Quote
Lee Mac Posted January 25, 2013 Posted January 25, 2013 One other thing I forgot to ask and that is how I can limit the numbers to whole numbers without and decimal places..http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Rounding-Text-to-Less-Decimal-Places/td-p/2510232 As per this link the setting in your program seems to be set to 0 but it still gives 4 places of decimals....Am I reading this wrong? The current program uses your settings for LUNITS & LUPREC since rtos is being called without the unit or precision parameters. To include these parameters, change: ([color=BLUE]setq[/color] p ([color=BLUE]mapcar[/color] '[color=BLUE]rtos[/color] ([color=BLUE]trans[/color] ([color=BLUE]trans[/color] x 3 2) 2 0))) to: (setq p (mapcar '(lambda ( x ) (rtos x [highlight]2[/highlight] [highlight]0[/highlight])) (trans (trans x 3 2) 2 0))) I have highlighted the units & precision parameters. Quote
woodman78 Posted January 25, 2013 Author Posted January 25, 2013 Thanks LeeMac, This is what I finished up with.. ;;Written by LeeMac: Modified by Woodman78 (defun c:vprec ( / _text l j k p ECL ECC ECE ) (setq ECL (getvar "clayer")) (setq ECC (getvar "cecolor")) (setq ECE (getvar "cmdecho")) (setq Layoutname (getvar "ctab")) (setq combinedlayer (strcat "CCC_SHEET_LAYOUT_ITM_Coordinates_"layoutname)) (setvar "cecolor" "Bylayer") ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (command "_.-layer" "_U" combinedlayer "") (command "laydel" "N" combinedlayer "" "YES") (command "_.-layer" "_N" combinedlayer "_M" combinedlayer "") (command "_.-layer" "_U" combinedlayer "") ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun _text ( s p r j ) (entmake (list '(0 . "TEXT") (cons 410 (getvar 'ctab)) (cons 040 5) (cons 007 (getvar 'textstyle)) (cons 010 p) (cons 011 p) (cons 001 s) (cons 050 r) (cons 072 j) '(73 . 2) ) ) ) (cond ( (= 1 (getvar 'tilemode)) (princ "\nCommand only available in Paperspace.") ) ( (= 1 (getvar 'cvport)) (princ "\nPlease activate a viewport.") ) ( (setq l (cdr (assoc (getvar 'cvport) (vports))) j '(2 0 2 0) k '(2 0 0 2) ) (foreach x (list (car l) (cadr l) (list (caadr l) (cadar l)) (list (caar l) (cadadr l))) (setq p (mapcar '(lambda ( x ) (rtos x 2 0)) (trans (trans x 3 2) 2 0))) (_text (strcat " E: " (car p) " ") x (/ pi 2.0) (car j)) (_text (strcat " N: " (cadr p) " ") x 0.0 (car k)) (setq j (cdr j) k (cdr k) ) ) ) ) (setvar "cecolor" ECC) (setvar "clayer" ECL) (command "_.-layer" "LO" combinedlayer "") (princ) ) My additions are crude I know....but they do seem to work. Quote
