Help modify lisp - align text & flow direction
Hello all;
I have download a lisp which can calculate the slope
between two manhole invert level ie the upstream and
downstream level. Then , the slope was indicate on the
pipe line ie slope 1:xxx
But something missing (I think); the text is not align to
the pipeline and no flow direction indicate (ie arrow line
indicate flow from upstream to downstream)
Any help to modify this Lisp is appreciated.
Thanks in advance
mh.lsp
Here ... try this:
(defun c:mh (/ *error* acdoc ss1 ss2 l n str e)
				; TharwaT 20. 04. 2011
 (vl-load-com)
 (defun *error* (msg)
   (or	(wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
(princ (strcat "\n** Error: " msg " **"))
 (setq acdoc (vla-get-ActiveDocument (vlax-get-acad-object)))
 (vla-StartUndoMark acdoc)
 (if
   (and
     (setq ss1 (entsel "\n Upstream numerical Text :"))
     (setq ss2 (entsel "\n Downstream numerical Text :"))
     (setq l (entsel "\n Select Pipe Line :"))
      (setq n (- (atof (cdr (assoc 1 (entget (car ss1)))))
	  (atof (cdr (assoc 1 (entget (car ss2)))))
      (setq
 str (/	(distance (cdr (assoc 10 (setq e (entget (car l)))))
		  (cdr (assoc 11 e))
	n
[color="red"] ang (angle (cdr (assoc 10 e))
	    (cdr (assoc 11 e))[/color]
     [color="red"](if (> n 0)
 (setq dir (strcat "1:" (rtos str 2 3) " --->"))
 (setq dir (strcat "<--- 1:" (rtos str 2 3)))
      )[/color]
      (entmakex (list (cons 0 "TEXT")
	       (cons 10 (getpoint "\n Text Location:"))
	       (cons 40 (getvar 'textsize))
	       [color="red"](cons 50 ang)
	       (cons 1 dir)[/color]
 (vla-EndUndoMark acdoc)
 (c:mh)
The modified parts are in red!
Give me some details on the arrow ... an example image would be helpful!
With regards Csaba Arpad Dobai!
Edited by CAD89
Completion of post
Hello, thanks for the reply.
The arrow seems NOT quite correct in some cases; as the flow should
be flowing from the upstream (higher height) to
downstream (lower height). See drawing example.
Thanks.
mh1.dwg
easiest way is to use the existing texts angle [ss1]
(Defun c:mh2 (/ ss1 ss2 l n str ang sp ep)
 (while (and
   (setq n (- (atof (cdr (assoc 1 [color=blue](setq ss1[/color] (entget (car ss1))))))
       (atof (cdr (assoc 1 (entget (car ss2)))))))
   (setq  str (abs (/ (distance
   [color=blue](setq sp[/color] (cdr (assoc 10 (setq e (entget (car l))))))
   [color=blue](setq ep[/color] (cdr (assoc 11 e)))
   )  n)))
  [color=blue] (setq ang (if (> (distance (cdr (assoc 10 ss1)) ep)
      (distance (cdr (assoc 10 ss1)) sp))
 (angle ep sp)(angle sp ep)))[/color]
   (entmakex
    (cons 10
   [color=blue] (cons 50 ang)[/color]
    (cons 1 (strcat "1:" (rtos str 2 0) "--->"))
HTH
Edited by pBe
Quick Fix
Hello pBE,
Not quite right, the "arrow" showing the flow is not parallel
to the pipeline; make it the annotation confusing. See the
example of drawings i attached.
Further help is very much grateful.:)
Thanks
mhdirn.dwg
i didn't actually see your drawing sample, i based my suggestion solely on the code you posted. If the attached file is 2010 version or higher i wont be able to view it. :)
Anyhow....
Somebody will come along and "fix" it for you.
Cheers
Edited by pBe
Quick fix for you
[/b]
I had one of my buddies to convert the file to a lower version
HTH
It is OK for me at a lower version;
so pBe........... can you help?
I updated the code on my previous post [#4]
Oh.........:oops: I still can't get the flow
direction right?????
