(using AutoCAD 2000)
Hello
I have a quick XRef question. Can someone help me with some VB code that “searches” among attached XRefs? I need to go through hundreds of drawings and if they contain a certain XRef – I want to remove it.
The XRef to be removed from the drawings has a static name, so that should make it easier – but I’m not sure how to incorporate an XRef “search” function into a program.
Basically I want to:
- open every drawing in a folder (I already have the code to do that)
- search for an XRef named “Base-Drawing”
- if it exists I want to remove it. If it does not exist I want to move to the next drawing
Is it possible to search XRefs in that manner? Can someone help me?
Thank you
Mike
use Objectdbx to do this - its heaps quicker opening drawings quietly then actually opening the drawing in autocad
I dont have vb infront of me and i cant remeber the code to detach but you should be able to work it out
Let me know how you go
Cheers
Option Explicit
Sub CHANGEXREFS ()
Dim AcadDbx As AxdbDocument
Dim Direc As String
Dim Elem as object
Dim Filenom as string
Dim Wholefile as string
Set AcadDbx = GetInterfaceObject("OjectDBX.AxDbDocument.17")
On Error Resume Next
Direc = "c:\program files\AutoCAD Civil 3D 2008\Sample" 'Change to your directory or link directory to a form
Filenom = Dir$(Direc & "\*.dwg")
Do While filenom <> ""
Wholefile = Direc & "\" & filenom
msgbox wholefile ' i just put this here to show you that it is opening the files
AcadDbx.open Wholefile
For Each Elem In AcadDbx.Blocks
   If elem.IsXRef = True and elem.name = "Base-Drawing" then
Msgbox "PUT YOUR CODE HERE WHAT YOU WNAT TO DO WITH THE XREF"
'it should be something like 'elem.Detach = true (cant remember)
End if
Next 'Next Elem
Set Elem = Nothing
Filenom = Dir$
Loop
set AcadDbx = Nothing
end sub
Aargh, hmmmmm. Can someone tell me why I get a “loop not initialized” error when I add a second XRef to the code?
For Each Elem In [color=black]AcadDbx.Blocks[/color]
   If Elem.IsXRef = True And Elem.Name = "[color=black]Base-Drawing"[/color] Or Elem.IsXRef = True And Elem.Name = "Temp-Base" Then
   Elem.Detach
   End If
Next
No way for me to test this but try:
   If Elem.IsXRef = True And (Elem.Name = "Base-Drawing" Or Elem.Name = "Temp-Base") Then
   Elem.Detach
   End If
Next
That worked. I don't know why it made a difference but it worked and it's cleaner so I'm not going to wonder about it for too long! lol
Thanks for all your help!
  • 2 weeks later...
Is there a way to modify this script to make a list of drawings the xref is linked to instead of deleting the xref? For example, I have an xref drawing named "site plan" and it is linked to 20 other drawings. I want to print a list of those drawings "site plan" is referenced.
