Delete all attributes except for certain blocks
I need to have a lisp routine that will delete all attributes in all block except for certain blocks. Those few need to stay. Also it needs little to no user input.
I found this lisp but I don't have a clue on how to add an exclusion list of block names to it. If someone could point me in the right direction it would be appriciated.
(defun c:DelTXT (/ ss i sn x)(vl-load-com)
 (if (setq ss (ssget '((0 . "INSERT") (66 . 1))))
     (setq sn (ssname ss (setq i (1- i))))
     (while
       (not
         (eq (cdr (assoc 0 (entget (setq x (entnext sn))))) "SEQEND")
        (if (eq (cdr (assoc 0 (entget x))) "ATTRIB")
          (vla-delete
            (vlax-ename->vla-object (cdr (assoc -1 (entget x))))
Thnaks
Sean
Maybe you can do that by the layer that the block lays on
I think that code is written by me if I am not mistaken . :)
Yes I think it is yours and thank you for sharing it. I tried locking the layer that the block was on but if the block definition has the text on layer zero it will still delete the attribute. My issue is I need the room id block, door tag's and the like not to be effected yet delete text from chairs or desks.
I suppose that would work but one of the blocks is room name and number and could be any value. On top of that I have no clue how. There are only ten block names I need to exclude. With your routine I select all and then tried to remove but you can't remove by name.
If your blocks are not in a way confidential works , just upload a sample drawing to have a look at it , we may can find a way to hit it down to the floor . :)
Here is the drawing. Ideally the routine would select all then exclude or remove these blocks from the selection. Bubble, gridbubble-b, gridbubble-l, gridbubble-t, gridbubble-r, rmnm-no, dr-no, windowtype, partiontype, iden.
Testing-2.dwg
What are the name of blocks that you do not want to delete their attributes ?
Did it work for you? It deletes the attributes in all the blocks still.
My mistake was with number 8 instead of 2 . :)
Try it now ...
(defun c:Test (/ ss i sn x)
;;; Tharwat 30. Jan. 2013 ;;;
 (vl-load-com)
 (if (setq ss (ssget "_x" '((0 . "INSERT") (66 . 1))))
     (if (not (member (strcase (cdr (assoc 2 (entget sn))))
                      '("BUBBLE"          "GRIDBUBBLE-B"
                        "GRIDBUBBLE-L"    "GRIDBUBBLE-T"
                        "GRIDBUBBLE-R"    "RMNM-NO"
                        "DR-NO"           "WINDOWTYPE"
                        "PARTIONTYPE"     "IDEN"
       (while
         (not
            (vla-delete
Thank you so much!!!
Try it now ...
 (vl-load-com)
       (while
         (not
            (vla-delete
Tharwat,
Is there any significance to the block list being in two columns? I tried adding another block name and is not catching that block. Is there something special I need to do if adding another block name to the list?
Thanks,
Sean
Tharwat,
No at all , that is something related to Visual Lisp editor formatting way .
Tharwat,
Is there any s I tried adding another block name and is not catching that block. Is there something special I need to do if adding another block name to the list?
Thanks,
Sean
The Block name must be add as a string with capital letter . e.g. "BLOCK NAME"
Good luck :)
