Unable to Add Segments to Alignment
Hello,
I have an alignment that I created a while back and need to extend it by adding some curves and lines to it. I right-clicked on the alignment > Edit alignment, and started adding lines and curves using the alignment tools. The alignment then appears to be lengthened, however when I pull up the properties, the length has not changed nor have the labels updated. It also won't let me add a station/offset label along the new segments.
The alignment is over 3,000 feet long with many curves and I don't want to have to recreate it. :(
Thoughts?
It's possible that the end of the existing alignment and the beginning of the new segments are just a microscopic space apart. If they don't meet exactly, they don't join to the alignment.
Another possibility is that the new segments are part of a different, new alignment. It's easy to do. If you redefine their alignment, they should pop into place.
