samifox Posted January 31, 2013 Posted January 31, 2013 Hello Using AutoCAD 2010, I use the express extrim to trim by a shape, I would like to add it to my customized tool Platte, i Right click on my tool palette and select customized command, than Type “Extrim” , Nothing found Is there a way to add it to my tool palette? Thanks Shay Quote
dbroada Posted January 31, 2013 Posted January 31, 2013 What you can do (don't know if this messes anything else up or not though) is drag one of the other commands - I used btrim - to your palette. Now go in to the properties of that command and change the btrim to extrim. If you do it the same way as I did remove one of the two spaces at the end of the command. Quote
samifox Posted January 31, 2013 Author Posted January 31, 2013 Work like a charm! Thanks a lot:d Quote
