Hello again,
Here I am again with some new questions regarding my new problem. You see I have been following one video tutorial that came along with exercise files and so far It went all good. Now I have reached to the point where the talk about rendering, setting up the location, sun, shadows and so on. I did follow every step along this lesson but I don´t get the same result as they do. You can see from the pictures that I attached what is the problem. When I set the full shadow option from what I can see nothing changes. It is only when I use “ground shadow” that the shadows can be seen. So what is the problem, what am I doing wrong? Is it something that Ineed to turn on/off or?
Thanks in advance and best regards to you all!
Miro
I think it only displays full shadows in the render.
