How to heal after deleting a face
I used the Remove Face command and it left the solid without a volume.
I cannot use the replace face command because there isn't any volume, even after i completed the missing faces with The Boundary Patch command.
How to complete the solid again?
I know there is the Heal option in the Remove Face command, but i want to learn to do it outside.
Move Face.ipt
There is no "Remove Face" command in my version, maybe this is a language translation problem.
Are you using an English language version of Inventor?
Try the Stitch command and select the two surface bodies to stitch back into a solid body.
This is version 2009, and it's called Delete face, but i will try the Stitch command.
You must be very precise in your problem descriptions to avoid confusion.
I used the Stitch command and afterwards the Replace Face command on the new created solid and it succeeded.
I ask what is a quilt, it's written in the help, since with the stitch command, i combined a 3D surface with ordinary solid faces, to create a solid
....i combined a 3D surface with ordinary solid faces, to create a solid
I don't think so.
Can you attach file that proves this?
When you did a Delete Face you no longer had an "ordinary solid faces" - if you look in the browser you should see a folder that says Surface Bodies, not Solid Bodies.
A quilt is several surface bodies stitched together.
When you delete a face from a solid you are left with a quilt (several sitched surfaces)
or
when you stitch several surface together that do not for a watertight volume you get a quilt (surface body) rather than a solid.
I don't see no surface bodies, no solid bodies folder in the file attached.
And the Replace command worked, so i guessed it works only on solids.
Ans also, after the Stitch command it looked as a solid, all grey.
Move Face.ipt
...it looked as a solid, all grey.
I forgot you are using a 4-yr old release, much has changed.
In any case, don't be fooled be color. All grey does not mean it is a solid.
It is solid when the part has volume (iProperties) and you can use solid editing tools. (it was all grey when you did Delete Face, but not a solid)
