Disabling hatch display
hi
often the hatches in the drawing is so dense i cant navigate. is there a way the disable hatches display?
Thanks
Shay
Why don't you just freeze the layer the hatch patterns are on?
Try this instead.
You can disable the interactive hatch previews - e.g. for large drawings or on a slower computer - with the HPQUICKPREVIEW variable. Set it to Off.
You may hide the hatches by setting the FILLMODE system variable to 0. It will require a REGEN call to have effect on existing entities. Just don't forget to reset it when is time to print or deliver the drawing.
my autocad (not lt) doesnt know what is HPQUICKPREVIEW..have any idea?
FILLMODE do what i want
Thank you
S
In the link suggested by ReMark is noted that the said variable is available in AutoCAD starting with version 2011.
Once upon a time you could just issue the command FILL OFF at the prompt. Did the job.
