Auto Track alignment path display
Can you change how AutoTrack displays alignment paths
Got it....
Options/Drafting/Auto Snap Settings/ Colors
what about the dashed vector lines, can you set the line type?
Yes.
I don't have access to it at the moment although you click the sweep path, then click the properties button (it is red and yellow I think) on one of the AutoTrack toolbars and in the dialog window that appears, you can select the various 'reports' as it calls it and edit those where you can change all the display properties(including linetypes, colours, hatching etc) and turn on/off components also. If you save as default those properties once you have them how you want, then future sweep paths you do will also automatically take on those properties.
Got it....
Options/Drafting/Auto Snap Settings/Colors and set the color for Autotrack vector, you need to set this as desired in each context. Perhaps an example of what lines you are calling what name is needed.
Yes.
Using the response in post #2, I believe the OP is talking about Autotracking in AutoCAD, not the program AutoTrack.
