I have found several lisp files that creating and loading the dialog box; Without a seperate DCL file.Is there any lessons available to learn that method?
To don't have to worry about supplying two files for a tool, one programmer may include the DCL definition as a string/list of strings into his/her AutoLISP code and at run-time deflate it into Temp folder (check TEMPREFIX system variable) and call it from there.
Here is an example you have to use pass the items eg (setq title "Please select an item")
(setq title "Please enter dwg number")
(setq width "   edit_width = 12;")
(setq limit "     edit_limit = 9;")
(ah:getval title width limit)
(setq dwgname item)
2nd lisp
;; Input  Dialog box with variable title
;; By Ah June 2012 adapted from original code by  ;; Alan J. Thompson, 09.23.08 / 05.17.10 (rewrite)
;; code (ah:getval title)
(defun AH:Getval (title width limit / fo)
(setq fname "C://acadtemp//getval.dcl")
(setq fo (open fname "w"))
(write-line "ddgetval : dialog {" fo)
(write-line " : row {" fo)
(write-line ": edit_box {" fo)
(write-line (strcat "    key = "  (chr 34) "sizze" (chr 34) ";") fo)
(write-line  (strcat " label = "  (chr 34) title (chr 34) ";"  )   fo)
; these can be replaced with shorter value etc
;(write-line "     edit_width = 18;" fo)
;(write-line "     edit_limit = 15;" fo)
(write-line width fo)
(write-line limit fo)
(write-line "   is_enabled = true;" fo)
(write-line "    }" fo)
(write-line "ok_cancel;}" fo)
(close fo)
(setq dcl_id (load_dialog  "c:\\acadtemp\\getval"))
(if (not (new_dialog "ddgetval" dcl_id))
(exit))
(action_tile "sizze" "(setq item  $value)(done_dialog)")
(mode_tile "sizze" 3)
(start_dialog)
; returns the value of item
Another method posted a while ago
 (SETQ reply (ACET-UI-MESSAGE "Choose dude "
                             "Russells Dialog"
                             (+ Acet:YESNOCANCEL Acet:ICONWARNING)
;; Yes = 6
;; No = 7
;; Cancel = 2
(IF (= reply 6)
 (PROGN (ALERT "Yep")
        ;; More Yes Mojo
 ;; else
 (PROGN (ALERT "Nope")
        ;; More no mojo
Edited by BIGAL
Thanks I will try to start studing these codes.
