I am making one of my first tentative forays into LISP writing. All I want to do at the moment is use a LISP to run a script of mine.
Here's what it consists of at the moment:
(DEFUN C:LDS200-0 ()
(command "script" "C:\\0_LAYER PROPERTIES.scr")
The above works fine. However, my problem is that the script above is just a copy of the actual script which is on a networked drive (hosted on a different PC). I cannot get the LISP to locate the script in its actual location. In fact, the only place where the LISP can see the script is when it's directly on my C drive (ie: not even in a folder on my PC's C drive). Am I limited to placing my scripts here directly on my C drive, or is it possible for my LISP to find the script on the network drive?
Maybe something similar to this
"\\\\server\\script folder\\0_LAYER PROPERTIES.scr"
Thanks. I tried that, and the path that AutoCAD looked in is correct, but I end up with an invalid file name error:
This line in my LISP....
(command "script" "K:\\\\_LDS JOB DATA\\RE_FILES\\DRAWING SCRIPTS\\0_LAYER PROPERTIES.scr")
....returned this message:
"K:\\_LDS JOB DATA\RE_FILES\DRAWING SCRIPTS\0_LAYER PROPERTIES.scr": Invalid file name
Looks like you're accessing a drive, and not a server location - try beginning with:
(command "_script" "K:\\........")
I'm not too good with these types of LISPs though - so there is a good chance I may be wrong :oops:
Thanks, but I get exactly the same message....
ok, this may be a long shot, but is there any way of dumping the script file into the ACAD program files (i.e. in with the support files), then include in your code:
(command "_script" "0_LAYER PROPERTIES")
Not sure if this will work at all, but I know that with inserting blocks, running LISPs, etc etc, if just a filename is specified, ACAD will search some default locations for that file - support files being one of those locations.
Worth a go all the same :P
I guess I could, but I'm not the only person that uses this script, so it would be a pain to have it in more than one place. Best solution is to have it on the network drive so that everyone can access it & it only needs to get edited in one place etc etc
Good point. But now I'm fresh out of ideas :(
Does anyone else have any ideas on this?
Thanks for the tip, but that doesn't solve my problem....
I do not really work with scripts much but maybe we are not typing what you are expecting..
try
(command "_script" "K:\\0_LAYER PROPERTIES")
change the "K" to the drive letter you are using and use double slashes to denote folders
any luck?
try
any luck?
Nope - that doesn't work either, but I have found that using / instead of \ does! So problem solved, hooray!! Thanks all for your suggestions :)
