phoenix2009 Posted February 12, 2013 Author Share Posted February 12, 2013 Thanks again Lee Mac!! But how to find crossing points then? Quote Link to comment Share on other sites More sharing options...
zamri_uut Posted August 11, 2013 Share Posted August 11, 2013 Sorry Mr. Lee Mac, please help me ! Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 11, 2013 Share Posted August 11, 2013 zami: Your request is somewhat lacking in detail. Could you elaborate further? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 11, 2013 Share Posted August 11, 2013 Sorry Mr. Lee Mac, please help me ! Which code post are you referring to (#15 / #16 / #20)? Quote Link to comment Share on other sites More sharing options...
zamri_uut Posted August 11, 2013 Share Posted August 11, 2013 Sorry for my english... Post #16.. The line is crossing.. Thanks. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 11, 2013 Share Posted August 11, 2013 Try this modification: ([color=BLUE]defun[/color] c:test ( [color=BLUE]/[/color] a1 d1 d2 d3 e1 e2 p1 p2 sp xl zv ) ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]setq[/color] e1 (LM:ssget [color=MAROON]"\nSelect 1st Polyline: "[/color] '([color=MAROON]"_+.:E:S"[/color] ((0 . [color=MAROON]"LWPOLYLINE"[/color]))))) ([color=BLUE]setq[/color] e2 (LM:ssget [color=MAROON]"\nSelect 2nd Polyline: "[/color] '([color=MAROON]"_+.:E:S"[/color] ((0 . [color=MAROON]"LWPOLYLINE"[/color]))))) ([color=BLUE]progn[/color] ([color=BLUE]initget[/color] 6) ([color=BLUE]setq[/color] d1 ([color=BLUE]getdist[/color] [color=MAROON]"\nSpecify Step Distance: "[/color])) ) ) ([color=BLUE]progn[/color] ([color=BLUE]setq[/color] d3 ([color=BLUE]-[/color] d1) e1 ([color=BLUE]ssname[/color] e1 0) e2 ([color=BLUE]vlax-ename->vla-object[/color] ([color=BLUE]ssname[/color] e2 0)) d2 ([color=BLUE]vlax-curve-getdistatparam[/color] e1 ([color=BLUE]vlax-curve-getendparam[/color] e1)) zv ([color=BLUE]trans[/color] '(0.0 0.0 1.0) 1 0 [color=BLUE]t[/color]) sp ([color=BLUE]vlax-get-property[/color] ([color=BLUE]vla-get-activedocument[/color] ([color=BLUE]vlax-get-acad-object[/color])) ([color=BLUE]if[/color] ([color=BLUE]=[/color] 1 ([color=BLUE]getvar[/color] 'cvport)) 'paperspace 'modelspace) ) ) ([color=BLUE]while[/color] ([color=BLUE]<=[/color] ([color=BLUE]setq[/color] d3 ([color=BLUE]+[/color] d3 d1)) d2) ([color=BLUE]setq[/color] p1 ([color=BLUE]vlax-curve-getpointatdist[/color] e1 d3) a1 ([color=BLUE]-[/color] ([color=BLUE]angle[/color] '(0.0 0.0) ([color=BLUE]trans[/color] ([color=BLUE]vlax-curve-getfirstderiv[/color] e1 ([color=BLUE]vlax-curve-getparamatpoint[/color] e1 p1)) 0 1)) ([color=BLUE]/[/color] [color=BLUE]pi[/color] 2.0)) xl ([color=BLUE]vlax-invoke[/color] sp 'addxline p1 ([color=BLUE]trans[/color] ([color=BLUE]polar[/color] ([color=BLUE]trans[/color] p1 0 1) a1 1.0) 1 0)) ) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] p2 ([color=BLUE]car[/color] ([color=BLUE]vl-sort[/color] (LM:group3 ([color=BLUE]vlax-invoke[/color] xl 'intersectwith e2 [color=BLUE]acextendthisentity[/color])) '([color=BLUE]lambda[/color] ( a b ) ([color=BLUE]<[/color] ([color=BLUE]distance[/color] a p1) ([color=BLUE]distance[/color] b p1))) ) ) ) ([color=BLUE]progn[/color] ([color=BLUE]entmake[/color] ([color=BLUE]list[/color] '(0 . [color=MAROON]"LINE"[/color]) ([color=BLUE]cons[/color] 10 p1) ([color=BLUE]cons[/color] 11 p2))) ([color=BLUE]entmake[/color] ([color=BLUE]list[/color] '(0 . [color=MAROON]"TEXT"[/color]) ([color=BLUE]cons[/color] 10 ([color=BLUE]trans[/color] p1 0 zv)) ([color=BLUE]cons[/color] 11 ([color=BLUE]trans[/color] p1 0 zv)) ([color=BLUE]cons[/color] 50 ([color=BLUE]+[/color] a1 ([color=BLUE]angle[/color] '(0.0 0.0) ([color=BLUE]trans[/color] ([color=BLUE]getvar[/color] 'ucsxdir) 0 zv [color=BLUE]t[/color])))) ([color=BLUE]cons[/color] 40 ([color=BLUE]getvar[/color] 'textsize)) ([color=BLUE]cons[/color] 07 ([color=BLUE]getvar[/color] 'textstyle)) ([color=BLUE]cons[/color] 01 ([color=BLUE]strcat[/color] [color=MAROON]"L="[/color] ([color=BLUE]rtos[/color] ([color=BLUE]distance[/color] p1 p2) 2) [color=MAROON]"m"[/color])) '(72 . 0) '(73 . 2) ([color=BLUE]cons[/color] 210 zv) ) ) ) ) ([color=BLUE]vla-delete[/color] xl) ) ) ) ([color=BLUE]princ[/color]) ) ([color=BLUE]defun[/color] LM:group3 ( lst [color=BLUE]/[/color] rtn ) ([color=BLUE]repeat[/color] ([color=BLUE]/[/color] ([color=BLUE]length[/color] lst) 3) ([color=BLUE]setq[/color] rtn ([color=BLUE]cons[/color] ([color=BLUE]list[/color] ([color=BLUE]car[/color] lst) ([color=BLUE]cadr[/color] lst) ([color=BLUE]caddr[/color] lst)) rtn) lst ([color=BLUE]cdddr[/color] lst) ) ) ([color=BLUE]reverse[/color] rtn) ) [color=GREEN];; ssget - Lee Mac[/color] [color=GREEN];; A wrapper for the ssget function to permit the use of a custom selection prompt[/color] ([color=BLUE]defun[/color] LM:ssget ( msg params [color=BLUE]/[/color] sel ) ([color=BLUE]princ[/color] msg) ([color=BLUE]setvar[/color] 'nomutt 1) ([color=BLUE]setq[/color] sel ([color=BLUE]vl-catch-all-apply[/color] '[color=BLUE]ssget[/color] params)) ([color=BLUE]setvar[/color] 'nomutt 0) ([color=BLUE]if[/color] ([color=BLUE]not[/color] ([color=BLUE]vl-catch-all-error-p[/color] sel)) sel) ) ([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color]) Quote Link to comment Share on other sites More sharing options...
zamri_uut Posted August 11, 2013 Share Posted August 11, 2013 Well done ! Thank you Mr. Lee Mac... You are the best..! Quote Link to comment Share on other sites More sharing options...
folderdash Posted July 2, 2014 Share Posted July 2, 2014 Thanks for your lisp in Post #26.But in this lisp the dimension is not written at the start and the end of the polyline.First dimension is written after the specified step distance.Is it possible to add dimensions to start and the end of the polyline? Thanks Umit Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 2, 2014 Share Posted July 2, 2014 Thanks for your lisp in Post #26.But in this lisp the dimension is not written at the start and the end of the polyline.First dimension is written after the specified step distance.Is it possible to add dimensions to start and the end of the polyline? The dimensions will start at the startpoint of the first polyline selected, and will continue until the step distance exceeds the length of this first polyline. Quote Link to comment Share on other sites More sharing options...
doru10 Posted April 21, 2015 Share Posted April 21, 2015 (edited) Hi, I have many longitudinal profile (hundreds). This Longitudinal Profile is made using the program URBANO-Canalis. What should I do is to extract the depth of excavation. If trim the line the text change of field line length (blue color). I am attaching an sample. All the best. Best Regards, Doru Depth Category.dwg Edited April 23, 2015 by doru10 Quote Link to comment Share on other sites More sharing options...
doru10 Posted April 23, 2015 Share Posted April 23, 2015 Hi mister Lee, Is a very good Lisp but help me more if value should be field - line lenght. All the best. Best Regards, Doru Quote Link to comment Share on other sites More sharing options...
