Would like to know if Autocad has any thing that i could use to break multiple line at one time with out going to each line and using the break command. Using Autocad 13.
If you drew 2 lines as your break then trim pick 2 lines and use F to pick start & end point beween the 2 lines F= fence line like dragging over.
