RBPrice Posted February 7, 2013 Posted February 7, 2013 What level of the ACIS file is acceptable to 2013? And does anyone know of a coverter to change the ACIS level of a file so the wonderuos, up to the minute, top of the line, supercalifragilistic 2013, can import an ACIS file without being a pain in the butt? Thanks Quote
JD Mather Posted February 7, 2013 Posted February 7, 2013 (edited) ACIS (*.sat) is now up to something over v18. Autodesk was involved in a big lawsuit with Spatial several years ago and after that stopped using ACIS. Autodesk products are limited to reading ACIS v7. Search Google for free Hoops ACIS Viewer. The location in the viewer to convert down to v7 file is not where you might expect it in the menu structure - so look around. Edited February 8, 2013 by JD Mather Quote
RBPrice Posted February 8, 2013 Author Posted February 8, 2013 (edited) Thanks a bunch JD. Does that shortcoming also apply to Inventor too? Edited February 8, 2013 by RBPrice Quote
JD Mather Posted February 8, 2013 Posted February 8, 2013 Thanks a bunch JD. Does that shortcoming also apply to Inventor too? Autodesk products are limited to reading ACIS v7. I am not sure if they have reached an agreement with Spatial for Fusion 360 http://usa.autodesk.com/adsk/servlet/pc/index?id=20884205&siteID=123112 considering the history http://www.google.com/#hl=en&tbo=d&sclient=psy-ab&q=autodesk+spatial+acis+lawsuit&oq=autodesk+spatial+acis+lawsuit&gs_l=hp.3...2980849.2990580.0.2991483.29.25.0.4.4.0.498.4195.3j13j4j2j1.23.0.les%3B..0.0...1c.1.2.hp.oBe6xgPvbU8&pbx=1&bav=on.2,or.r_gc.r_pw.r_qf.&bvm=bv.42080656,d.dmQ&fp=dd466a211c9f3744&biw=740&bih=347 I doubt it. Quote
RBPrice Posted February 8, 2013 Author Posted February 8, 2013 Here's a liink to a simple converter - http://www.cadexchanger.com/ Open the file that AutoCAD can't read then do a Save and choose the same file name, Yes to Replace and bingo, AutoCAD can open it. Not sure what the magic is but it seems to work. Quote
JD Mather Posted February 8, 2013 Posted February 8, 2013 .... Not sure what the magic is but it seems to work. What file format is the result? *.sat? Open the original in Notepad - what version of ACIS does it say in first couple of lines? Open the converted in Notepad - what version of ACIS does it say? Quote
RBPrice Posted February 8, 2013 Author Posted February 8, 2013 Well JD - I coinfess that I assumed it was .SAT since I invoked the ACISIN command to fetch it. And I assumed that it was V7 or lower because AutoCAD 2013 had no trouble opening it. But I also confess that I did not look at the file since it solved my problem of importing a 3D solid shoullder bolt from the McMaster-Carr folks. RBP Quote
SLW210 Posted February 11, 2013 Posted February 11, 2013 I've had problems with a few of McMaster-Carr's .sat files. I do not believe it is the version, just thier method of converting, I have better luck downloading the STEP and opening with Inventor Fusion and saving as AutoCAD 2010 .dwg. MOST of thier .sat files work fine. Quote
RBPrice Posted February 11, 2013 Author Posted February 11, 2013 That has been my experience also but the cadexchanger thingy is quick and simple. I also discovered that the Carr-Lane folks specifically allow you to specify what flavor of .SAT you want to download. Cheers Quote
