craig420 Posted February 8, 2013 Posted February 8, 2013 Hey all, Hopefully someone can help me out with this as I really am not very good at LISP at all, I find it very hard to follow even though I use other programming languages regularly. A while ago someone on this forum was kind enough to help me make a script which will search a CAD drawing for blocks containing two specific attributes. The script works great and is very handy because obviously Find/Search/Replace can only look for one attribute, so for example we may want to find a tag "TT2010" and if we used the built in search function, we could only find either all "TT" tags or all "2010" tags- of which there are many. I would like to somehow edit the script to select the tag(s) it finds so it operates in just the same way as the built in search function. I have had a look around a few forums and tutorials on the internet but as I said, I find the code very hard to follow. However I assume that what I am trying to do is very simple. Any help would be greatly appreciated and here is the existing LISP code: (defun c:Tag() (setq ss (ssget "X" (list '(0 . "INSERT") '(66 . 1)))) (setq a1 (getstring "\n1st attribute to search for ") a2 (getstring "\n2nd attribute to search for ") found 0 ) (repeat (setq i (sslength ss)) (if (check (ssname ss (setq i (1- i))) a1 a2) (setq found (1+ found))) (ssget "_X" '((0 . "INSERT") (2 . a1 a2))) ) (strcat " ---> " (itoa found) " Tags Found with that name") ) (defun check (en a1 a2) (setq hit 0 a0 (cdr (assoc 0 (setq el (entget en))))) (while (/= a0 "SEQEND") (if (= a0 "ATTRIB") (if (member (cdr (assoc 1 el)) (list a1 a2)) (setq hit (1+ hit)))) (setq a0 (cdr (assoc 0 (setq el (entget (setq en (entnext en))))))) ) (= hit 2) ) Thanks in advance, lifeis Quote
BIGAL Posted February 8, 2013 Posted February 8, 2013 maybe something like this, re zoom you can also use vl-get-insertionpoint then Z C scale (setq oldtag1 "DRAWING_STATUS") ;attribute tag name (setq newstr1 "ISSUED FOR CONSTRUCTION") (setq oldtag2 "REV_NO") ;attribute tag name (setq newstr2 "0") (setq ss1 (ssget "x" '((0 . "INSERT") (2 . "DA1DRTXT")))) (setq inc (sslength ss1)) (repeat inc (foreach att (vlax-invoke (vlax-ename->vla-object (ssname SS1 (setq inc (1- inc)) )) 'getattributes) (if (= oldtag1 (strcase (vla-get-tagstring att))) (vla-put-textstring att newstr1) ) ; end if (if (= oldtag2 (strcase (vla-get-tagstring att))) (vla-put-textstring att newstr2) ) ; end if ) ; end for ) ;end repeat Quote
craig420 Posted February 11, 2013 Author Posted February 11, 2013 BIGALmaybe something like this, re zoom you can also use vl-get-insertionpoint then Z C scale Thanks for your reply. I have tried playing around with your script but I just cant get it to run. Where in the code is the part that selects the object? And would I just add it here: (defun c:Tag() (setq ss (ssget "X" (list '(0 . "INSERT") '(66 . 1)))) (setq a1 (getstring "\n1st attribute to search for ") a2 (getstring "\n2nd attribute to search for ") found 0 ) (repeat (setq i (sslength ss)) (if (check (ssname ss (setq i (1- i))) a1 a2) (setq found (1+ found))) (ssget "_X" '((0 . "INSERT") (2 . a1 a2))) **CODE TO SELECT OBJECT?** ) (strcat " ---> " (itoa found) " Tags Found with that name") ) (defun check (en a1 a2) (setq hit 0 a0 (cdr (assoc 0 (setq el (entget en))))) (while (/= a0 "SEQEND") (if (= a0 "ATTRIB") (if (member (cdr (assoc 1 el)) (list a1 a2)) (setq hit (1+ hit)))) **CODE TO SELECT OBJECT?** (setq a0 (cdr (assoc 0 (setq el (entget (setq en (entnext en))))))) ) (= hit 2) ) As I said, I find LISP very hard to follow, so I amn't even sure what the variable defined with the object is called (Im guessing its "a1 & a2" or "en a1 a2" if thats how you concatenate in LISP). So I just need to add code to select at the second while loop and variables a1 a2 should contain the tag data, so some pseudo code may look like- Add 1 to the hit variable for each found Highlight/Zoom to a1 a2 Is this correct and if so, what code do I add there to make the selection? Thank you very much for your help, its appreciated. -Craig Quote
craig420 Posted February 11, 2013 Author Posted February 11, 2013 Another thing to note is that 99% of the time, only one tag will be found (if more than one is found then this is a mistake) so the script should not have a problem highlighting or zooming to the selection. Quote
