Slow opening drawings
I don't know what else to do so if anyone has any ideas I would love to hear them.
I have a few drawings that have the EXACT same X-ref Files in them and about half of them take 10 minutes to open. Another one takes the normal 2 minutes.
I have purged the file. Run an Audit. Said yes to fixing Errors.
It seems to slow down when trying to load the X-refs. I have also purged and run an Audit on the X-ref themselves and removed any un-needed files.
It is driving me nuts it should not be taking this long to open a file.
I am running CAD 08. Nothing fancy with it for these.
I do have CAD Civil 3D desktop companion but am 90% sure I do not have any data in these drawings.
im not too sure how much of a difference it makes, but are there any filters or wipeouts on them?
are the drawing files the same size?
I removed the wipeout frames on all my x-refs
Filters?? Not even sure I know what this means HAHA :oops:
Crossing drawing approx 800KB takes 10 minutes
Alignment sheet approx 850KB takes no time at all to open
Have you tried to reset the scalelist? A similar thing happened to me and turned out to be that, Autocad 2009 does that whenever you open any drawing, although on other versions that doesnt happen, so better do it from time to time in some fo your drawings.
Although I am pretty sure this has been done since I have 09 at home and worked on these there I will gladly try anything again.
What is the command to run a scale reset?
Well that might just be my problem...
I just got an error when I tried to run it. "Index was outside the bounds of the array"
Make sure you're using the "-" in front of scalelistedit. A number of my problem consultant drawings will error if you use the pop-up box command.
Because so many of my 2008 consultant drawings come in so filthy I've created a custom command button with the following macro:
^C^C-purge;r;*;n;-scalelistedit;r;y;e;-purge;a;*;n;
The first kills all regapps and can cut down my filesizes by as much as half (acad will reload any it needs anyway)
d_lay123: Excellent advice there regarding killing unused regapps. People don't realize what they can do to a file size. Nice! Two thumbs up for you.
All should keep in mind: a regular purge does not get rid of regapps, only "-purge" Don't know why not. I don't write 'em, I just use 'em.
Deziree,
Not sure if you still need this but attached is a zip file for a scale list edit tool that we run on entire folders. It saves time and ensures that all files are being cleaned. The only caveat is that all drawing files in the folder that houses the drawings must be closed prior to running the utility.
Regards,
Foz
Scale_List_Cleanup_Utility_32bit.zip
note: this needs to be installed in the main autocad folder, otherwise it will not work.
That is correct and is explained in the readme.txt file included with the zip file but thanks for clarifying.
The utilities for cleaning the scales and the registered applications are on the Autodesk site under AutoCAD 2008 and 2009. They both work similar. They can clean out folders/subfolders.
