I am using acad2000i
If you are offline and do not have access to Autodesk Point A, you may try to fix the problem using the following utility. It will fix many of the most common problems.
If problems persist, contact your dealer for additional technical support
and keep getting a blob of pop-up menus trying to locate the outdated POINT A site. How do I disable that? Here is a copy of the message:
Today Error Recovery
dw(gsCaption2)A problem was detected in Today
