Hello everyone.
Since I am new to autolisp, please bare with me.
I need to do the following:
Create some choices (big|med|small) and have the user select his choice with the mouse which then will be written in a variable.
Any suggestions? :?
If you want mouse pick then you will need a dialouge box, a couple of choices do you want a square with a label or a "radio button" with label beside ? please advise There are other methods such as cheat way using a yes no cancel box
 (SETQ reply (ACET-UI-MESSAGE "Big Med Small Choose Button "
                             "Perifanos Dialog"
                             (+ Acet:YESNOCANCEL Acet:ICONWARNING)
;; Yes = 6
;; No = 7
;; Cancel = 2
(cond ((= reply 6)
 (ALERT "Big")
        ;; More 1
((= reply 6)
 (ALERT "med")
        ;; More 2
((= reply 2)
 (ALERT "small")
        ;; More  3
If you want mouse pick then you will need a dialouge box...
Or you can use Dynamic Input with getkword:
