macchi Posted February 14, 2013 Share Posted February 14, 2013 Has anyone experience with VM Player and AutoCAD (MAP 3D) 2013 ? For normal AutoCAD users it seams to be ok. But working with big drawings with xrefs and third party application (loaded or not) it's all sticky and slow (commands, typing, cursor). Same commands takes 3 minutes in the VM while on normal workstation it takes 5 seconds. Both Win7, 64b, 8GB, NviDia 2000. Marco Quote Link to comment Share on other sites More sharing options...
Guest AARi Posted February 27, 2013 Share Posted February 27, 2013 if you cannot use VMware Workstation or Server [i had got some problems with VM Player and RAM], you can try VBox. https://www.virtualbox.org/wiki/Downloads Quote Link to comment Share on other sites More sharing options...
Murph_map Posted February 28, 2013 Share Posted February 28, 2013 I had trouble running an older version of Map3D in it a few years back and gave up on it. I did know that when installing it you could set the amount of ram to us from the host machine and the default was way to low for MAP3D back then. Quote Link to comment Share on other sites More sharing options...
