Scaling feature lines
I have a bunch of feature lines and with grading on them, with different elevations. I just realize they are all the wrong size (they are rectangles; I'm building a lagoon). IS there a way to scale them so they maintain their z values with out messing up my model?
I can click on their corners and use .xy and then give them the z values, but my profiles seems to mess up that way.
Just a guess. If you scale one feature line from a base point at the same elevation, then the z value for it shouldn't change. If you're doing more than one, of course, the z will scale too, as you seem to imply with the last sentence.
