Change this Code to Run as a Command to Use in a Script
I stole this code from someone and modified it. It's probably insanely inefficient, but I barely know what I'm doing. Anyway, what it does is inserts a bunch of blocks from my block library into a drawing. I'm sure someone has a 10-line code for this, that I'd happily steal.
I'd like to be able to change this so that I can run it as a command with a script because I have a few other code blocks that I'm running with a script and I'd like to add this one. How can I mod this?
(defun open_dbx (dwg / dbx)
(if (< (atoi (substr (getvar "ACADVER") 1 2)) 16)
(setq dbx (vlax-create-object "ObjectDBX.AxDbDocument"))
(strcat "ObjectDBX.AxDbDocument."
(substr (getvar "ACADVER") 1 2)))))
(vla-open dbx dwg)
dbx
;Get "Valve" in 'ValveBlock_TapCard.dwg" file :
(setq Dbx (open_dbx "I:/Water_CAD_Details/TAP_BlockLibrary/ValveBlock_TapCard.dwg")) ; file name containing block
(vla-CopyObjects
Dbx
(vlax-safearray-fill
(vlax-make-safearray vlax-vbObject '(0 . 0))
(list (vla-item (vla-get-blocks dbx) "Valve")))
(vla-get-blocks
(vla-get-activedocument (vlax-get-acad-object))))
(vlax-release-object dbx) ;Clean-up
;Next block import
(setq Dbx (open_dbx "I:/Water_CAD_Details/TAP_BlockLibrary/ManholeBlock_TapCard.dwg")) ; file name containing block
(vla-CopyObjects
Dbx
(list (vla-item (vla-get-blocks dbx) "Manhole")))
(vla-get-blocks
;Next block import
(setq Dbx (open_dbx "I:/Water_CAD_Details/TAP_BlockLibrary/BuildingBlock_TapCard.dwg")) ; file name containing block
(vla-CopyObjects
Dbx
(list (vla-item (vla-get-blocks dbx) "Building")))
(vla-get-blocks
;Next block import
(setq Dbx (open_dbx "I:/Water_CAD_Details/TAP_BlockLibrary/CurbValveBlock_TapCard.dwg")) ; file name containing block
(vla-CopyObjects
Dbx
(list (vla-item (vla-get-blocks dbx) "CurbValve")))
(vla-get-blocks
;Next block import
(setq Dbx (open_dbx "I:/Water_CAD_Details/TAP_BlockLibrary/GateValveBlock_TapCard.dwg")) ; file name containing block
(vla-CopyObjects
Dbx
(list (vla-item (vla-get-blocks dbx) "GateValve")))
(vla-get-blocks
;Next block import
(setq Dbx (open_dbx "I:/Water_CAD_Details/TAP_BlockLibrary/HydrantBlock_TapCard.dwg")) ; file name containing block
(vla-CopyObjects
Dbx
(list (vla-item (vla-get-blocks dbx) "Hydrant")))
(vla-get-blocks
;Next block import
(setq Dbx (open_dbx "I:/Water_CAD_Details/TAP_BlockLibrary/MeterPitBlock_TapCard.dwg")) ; file name containing block
(vla-CopyObjects
Dbx
(list (vla-item (vla-get-blocks dbx) "MeterPit")))
(vla-get-blocks
;Next block import
(setq Dbx (open_dbx "I:/Water_CAD_Details/TAP_BlockLibrary/NArrowBlock_TapCard.dwg")) ; file name containing block
(vla-CopyObjects
Dbx
(list (vla-item (vla-get-blocks dbx) "NorthArrow")))
(vla-get-blocks
;Next block import
(setq Dbx (open_dbx "I:/Water_CAD_Details/TAP_BlockLibrary/PoleBlock_TapCard.dwg")) ; file name containing block
(vla-CopyObjects
Dbx
(list (vla-item (vla-get-blocks dbx) "Pole")))
(vla-get-blocks
;Next block import
(setq Dbx (open_dbx "I:/Water_CAD_Details/TAP_BlockLibrary/StreetNameBlock_TapCard.dwg")) ; file name containing block
(vla-CopyObjects
Dbx
(list (vla-item (vla-get-blocks dbx) "StreetName")))
(vla-get-blocks
;Next block import
(setq Dbx (open_dbx "I:/Water_CAD_Details/TAP_BlockLibrary/TapCardNumberBlock_TapCard.dwg")) ; file name containing block
(vla-CopyObjects
Dbx
(list (vla-item (vla-get-blocks dbx) "TapCardNumber")))
(vla-get-blocks
;Next block import
(setq Dbx (open_dbx "I:/Water_CAD_Details/TAP_BlockLibrary/WallBlock_TapCard.dwg")) ; file name containing block
(vla-CopyObjects
Dbx
(list (vla-item (vla-get-blocks dbx) "Wall")))
(vla-get-blocks
;Next block import
(setq Dbx (open_dbx "I:/Water_CAD_Details/TAP_BlockLibrary/WaterMainBlock_TapCard.dwg")) ; file name containing block
(vla-CopyObjects
Dbx
(list (vla-item (vla-get-blocks dbx) "WaterMain")))
(vla-get-blocks
We dont steal code we borrow !
I wouldn't do it the way in the code rather just have a list of blocks or a text file and 1 defun to do the insert part like you say 10 lines, if you want to do as a script just write down 1 line of the necessary command steps and copy and change block name save as a script.
I don't know how to use a script to run this. I have one that runs another lisp, and it has a command "tapconvert." How do I get a command so I can preload this script then run it with a script a bunch of times? I tried adding C: before open_dbx but that doesn't work. I want to change this so I can run it as a script, but I don't know how to either change it or get the script to open and run it.
I just added all this into the other lisp. Can't figure out how to get it to run in a script but that one will because the C: works. Unfortunately, I cannot figure out how to do the list thing you speak of, but it sounds good in theory =P
example of a script just type script
open dwg1 z e insert block1 0,0 1 1 0 insert block2 0,0 1 1 0 insert block3 z e close y
open dwg2 z e insert block1 0,0 1 1 0 insert block2 0,0 1 1 0 insert block3 z e close y
and so on
and so on
I was using AutoScript because it lets you select folders full of files and I have something like 12,000+ to run it on. So I want the script to apply to all those files, which AScript takes care of, then run a few .lsp's. I can preload ones that run with a command, but if it doesn't have that C: to set something to run as a command, I don't know how to get the script to run it. There appears to be like zero documentation on scripts anywhere... I have the ACAD Bible and the internet, but really don't see much. I know it's something simple, but just don't know the syntax.
