PotGuy Posted February 15, 2013 Posted February 15, 2013 What's the commnd to change the default line thickness in AutoCAD 2012? I know to PE - W - x Value, but is there a command that changes what a pl's width starts at? Quote
ReMark Posted February 15, 2013 Posted February 15, 2013 (edited) PLINEWID will work for polylines not for plain lines. You can always assign a lineweight to a particular layer then toggle the LWT option to display or not to display the lineweight on screen. Edited February 15, 2013 by ReMark Quote
PotGuy Posted February 15, 2013 Author Posted February 15, 2013 Only PL's are being a pain. Lineweights aren't controlled by me; I work for McAlpine who have their own default Linewieghts. Is there a way to ensure a PL drawn won't have a large default thickness? Quote
ReMark Posted February 15, 2013 Posted February 15, 2013 Use a small lisp routine to set the value of PLINEWID when you start a new drawing? Create a macro and assign it to a button? Use a snippet of code like this: (setvar "plinewid" 0.0125) Note: sets Pline width to 1/8"). Quote
PotGuy Posted February 15, 2013 Author Posted February 15, 2013 Use a small lisp routine to set the value of PLINEWID when you start a new drawing? Create a macro and assign it to a button? Don't know how to. May look at Tutorials around Forums. Quote
PotGuy Posted February 15, 2013 Author Posted February 15, 2013 I gave you one more option. Macros do you mean, or the Lineweights? Quote
ReMark Posted February 15, 2013 Posted February 15, 2013 Use a snippet of code like this: (setvar "plinewid" 0.0125) Note: sets Pline width to 1/8". Quote
PotGuy Posted February 15, 2013 Author Posted February 15, 2013 Use a snippet of code like this: (setvar "plinewid" 0.0125) Note: sets Pline width to 1/8"). Cheers ReMark. One question; is this a LISP or Macro? Quote
ReMark Posted February 15, 2013 Posted February 15, 2013 (edited) Lisp. A macro would look different. My suggestion would be to put that whole line in your acaddoc.lsp file so it will be loaded each time a drawing is opened. You might find this of interest re: setting system variables... http://envisioncad.com/tips/autocad-customization-set-system-variables/ Edited February 15, 2013 by ReMark Quote
