How to Know if a current drawing requires save.
Hi All,
Please Help.
With SDI set to 1, Filedia set to 0 and Lispinit set to 0.
I am trying to make a routine which open some drawings and add blocks inside them. I have noticed that the current drawing in which my routine uploaded and started functioning needs to be saved sometime. Is there a way to notify that a current drawing require save? because whenever i run the routine with the following code sometimes it ask "Do You Really Want to Discard Changes ?" and sometimes not if its a fresh or already saved drawing. I want to get rid off that question.
(vl-cmdf "_.Open" (strcat Directory "\\" (nth cntr DrawingList)))
(vl-cmdf "_.Qsave")
Any Help would be appreciated.
Thanks and Regards
Aaryan
You can look into DBMOD setting ( DataBaseMODified ) -David
