Guest AARi Posted February 17, 2013 Posted February 17, 2013 Well, i am relly newbie programing in AutoLisp, but i would like send you a question about renaming "attribute value" into a block with the commandLine I.ve got this problem, a topography plan with more or less 4000 points (NEZ) with not description into theirs attributes, because these descrition are in a outside text so i would like to put all descrition-value into the attribute-block to work in Civil3D More problems, all block are into the same layer : "PUNTOS G1" and finally problem, all blocks have got the same name: "PUNTO" Well, in any case i will have to click into each block to configure their new attribute-value, in the attribute-tag "Codigo". See the picture. 1- cannot use "-eattedit",becuuse promp the dialog box 2- cannot use "-attedit", for the same reason 3- cannot use "-atredit" into the commandline Command: -attedit Edit attributes one at a time? [Yes/No] : n Performing global editing of attribute values. Edit only attributes visible on screen? [Yes/No] : n Drawing must be regenerated afterwards. Enter block name specification : ; all block have got he same name Enter attribute tag specification : Codigo Enter attribute value specification : 4090 attributes selected. Enter string to change: Enter new string: PDZ If i use this command, i will rename all attribute-value for all block in the drawing [and i have to set 10 values for diferents kind of points] a)Command: (car(entsel)) Designe objeto: ; give me the entity name but "-attedit" require for the block-name (wicth is the same for all the block-points into the dwg) b) i found this script: (if (setq ent(entsel "\n Select a Block: ")) ;- Let the user select a block (progn (setq en(car ent)) ;- Get the entity name of the block (setq enlist(entget en)) ;- Get the DXF group codes (setq blkType(cdr(assoc 0 enlist))) ;- Save the type of entity (if (= blkType "INSERT") ;- If the entity type is an Insert entity (progn (if(= (cdr(assoc 66 enlist)) 1) ;- See if the attribute flag equals one (if so, attributes follow) (progn (setq en2(entnext en)) ;- Get the next sub-entity (setq enlist2(entget en2)) ;- Get the DXF group codes (while (/= (cdr(assoc 0 enlist2)) "SEQEND") ;- Start the while loop and keep ;- looping until SEQEND is found. (princ "\n ") ;-Print a new line (princ enlist2) ;- Print the attribute DXF group codes (setq en2(entnext en2)) ;- Get the next sub-entity (setq enlist2(entget en2)) ;- Get the DXF group codes ) ) ) ;- Close the if group code 66 = 1 statement ) ) ;- Close the if block type = "ATTRIB" statement ) ) ;- Close the if an Entity is selected statement wich give tthis info Select a Block: ((-1 . ) (0 . ATTRIB) (330 . ) (5 . A89A) (100 . AcDbEntity) (67 . 0) (410 . Model) (8 . Nº PUNTO) (100 . AcDbText) (10 458491.0 4.47677e+006 575.23) (40 . 0.75) (1 . 3691) (50 . 0.0) (41 . 1.0) (51 . 0.0) (7 . Standard) (71 . 0) (72 . 0) (11 0.0 0.0 575.23) (210 0.0 0.0 1.0) (100 . AcDbAttribute) (280 . 0) (2 . NPUNTO) (70 . 0) (73 . 0) (74 . 0) (280 . 0)) ((-1 . ) (0 . ATTRIB) (330 . ) (5 . A89B) (100 . AcDbEntity) (67 . 0) (410 . Model) (8 . COTA Z) (100 . AcDbText) (10 458493.0 4.47677e+006 575.23) (40 . 0.75) (1 . 575.23) (50 . 0.0) (41 . 1.0) (51 . 0.0) (7 . Standard) (71 . 0) (72 . 0) (11 0.0 0.0 575.23) (210 0.0 0.0 1.0) (100 . AcDbAttribute) (280 . 0) (2 . COTA) (70 . 0) (73 . 0) (74 . 0) (280 . 0)) ((-1 . ) (0 . ATTRIB) (330 . ) (5 . A89C) (100 . AcDbEntity) (67 . 0) (410 . Model) (8 . CODIGOS 2) (100 . AcDbText) (10 458493.0 4.47677e+006 575.23) (40 . 0.75) (1 . ) (50 . 0.0) (41 . 1.0) (51 . 0.0) (7 . Standard) (71 . 0) (72 . 0) (11 0.0 0.0 575.23) (210 0.0 0.0 1.0) (100 . AcDbAttribute) (280 . 0) (2 . CODIGO) (70 . 0) (73 . 0) (74 . 0) (280 . 0)) ((-1 . ) (0 . ATTRIB) (330 . ) (5 . A89D) (100 . AcDbEntity) (67 . 0) (410 . Model) (8 . 0) (100 . AcDbText) (10 458493.0 4.47676e+006 575.23) (40 . 0.75) (1 . 1) (50 . 0.0) (41 . 1.0) (51 . 0.0) (7 . Standard) (71 . 0) (72 . 0) (11 0.0 0.0 575.23) (210 0.0 0.0 1.0) (100 . AcDbAttribute) (280 . 0) (2 . NIVEL) (70 . 1) (73 . 0) (74 . 0) (280 . 0))((-1 . ) (0 . "SEQEND") (330 . ) (5 . "A89E") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "PUNTOS G1") (-2 . )) where codes (1 . ????) (2 . ????) give me information about ATTRIBUTE TAGS & ATTRIBTE-VALUES But in any case i don´´t know how to change into (2 . CODIGO) the real Value (1 . ???) actually blank So, will have the best decision,.. in any case i will have to click in each point one to one. 1. selecct one by one each point [with the same attribute value to be changed] into different layer to copy into another drawing and then apply "-atredit" to all of them 2. try to write a simple scrip in AutoLips to change these attribute value in each point many thanks for all best regards AARi Quote
BIGAL Posted February 18, 2013 Posted February 18, 2013 Have a look at this written in VL I find a bit easier to understand compared to nextent and assoc's when learning it chnges a couple of attribute values in 2 blocks. ; changes to issued for construction : thanks to lee mac for original code (vl-load-com) ; 1. Get current date in mm/dd/yy format. (defun ddmmyy (/ x today) (setvar "cmdecho" 0) (setq x (getvar "CDATE")) ; get current date (setq today ( rtos x 2 4)) ; convert to a string (setq date (strcat (substr today 7 2) "." (substr today 5 2) "." (substr today 3 2) )) ) (setq oldtag1 "DRAWING_STATUS") ;attribute tag name (setq newstr1 "ISSUED FOR CONSTRUCTION") (setq oldtag2 "REV_NO") ;attribute tag name (setq newstr2 "0") (setq ss1 (ssget "x" '((0 . "INSERT") (2 . "DA1DRTXT")))) (setq inc (sslength ss1)) (repeat inc (foreach att (vlax-invoke (vlax-ename->vla-object (ssname SS1 (setq inc (1- inc)) )) 'getattributes) (if (= oldtag1 (strcase (vla-get-tagstring att))) (vla-put-textstring att newstr1) ) ; end if (if (= oldtag2 (strcase (vla-get-tagstring att))) (vla-put-textstring att newstr2) ) ; end if ) ; end for ) ;end repeat (setq oldtag1 "REV-NO") (setq newstr1 "0") (ddmmyy) (setq oldtag2 "DATE") (setq newstr2 date) (setq oldtag3 "AMENDMENT") (setq newstr3 "ISSUED FOR CONSTRUCTION") (setq ss2 (ssget "x" '((0 . "INSERT") (2 . "REVTABLE")))) (setq inc (sslength ss2)) (repeat inc (foreach att (vlax-invoke (vlax-ename->vla-object (ssname ss2 (setq inc (1- inc)))) 'getattributes) (if (= oldtag1 (strcase (vla-get-tagstring att))) (vla-put-textstring att newstr1) ) (if (= oldtag2 (strcase (vla-get-tagstring att))) (vla-put-textstring att newstr2) ) (if (= oldtag3 (strcase (vla-get-tagstring att))) (vla-put-textstring att newstr3) ) ) ) (setq ss1 nil) ; (setq ss2 nil) (princ) Quote
Guest AARi Posted February 19, 2013 Posted February 19, 2013 many thanks BIGAL I will start to study the code ... [no easy or me, seams VisualLisp .arx] AARi Quote
BIGAL Posted February 20, 2013 Posted February 20, 2013 look for words like 'getattributes tagstring textstring get is to retrieve put is to change Quote
