Missing material preview in Material editor
I did this, and this might be of interest to some
If at any point you are missing a preview for your materials make sure the following are set correctly.
If your using v-ray materials your renderer should be set to vray
if your boxes are grey it might mean that you accidentally .. unlocked the material editor engine under -
Render settings- Assign renderer- Material editor
I had my renderer set to vray, but my material editor was unlocked and set to mental ray. I had no idea what was wrong until i went through all my render settings and whoa "thats not right" and i changed it to what it should be.
overall
No material previews or incorrect previews?
check default renderer
check material editor engine
Under Render setup->Assign renderer
