Inserting block (break line) using AutoLISP
Hi everyone,
I have a code that inserts a block that is included on all of my drawings. Sometimes a few hundred times on each drawing. It currently works, but I would like to eliminate a couple of the prompts to save pressing enter an extra 2 times.
I type the command "BB", then it prompts for insertion point, which is fine, then it prompts the following two things, which i would like to eliminate:
" Enter X scale factor, specify opposite corner, or [Corner/XYZ] : Enter Y scale factor : " and
" Pick Insertion point "
after those it prompts for rotation, which is also fine.
Here is the code:
(defun c:bb (/ pt)
 (while (setq pt (getpoint "\nPick Insertion point."))
   (command "-insert" "1-20 BREAK" "_non" pt "" pause)
Thanks in advance,
Lyndon
(command "_insert" "1-20 BREAK" "_Scale" "1" "_rotate" "0" "_non" pt "" pause)
Thanks for the reply, but that did not work as i can no longer specify the rotation.
Maybe:
   (command "-insert" "1-20 BREAK" "_non" pt 1 1 pause)
-David
Thank you David, that worked perfectly.
