Visual Lisp & AutoCAD Mechanical
How do I connect to and use AutoCA mechanical API using Visual Lisp.
I have tried hard but can't find how to do this.
Plrase help.
To see how AutoLISP interact with AutoCAD, I suggest you to follow a tutorial - the one at AfraLISP for example.
For a more precise response, it will be useful to describe what you are intending to automate.
Thank you but I am talking of AutoCAD Mechanical.
I am trying to add balloons using visual lisp.
I'm inferring a bit here, from old VBA experience, but what happens if this is used?
(setq symBB (vla-getinterfaceobject (vlax-get-acadobject)"SymBBAuto.McadSymbolBBMgr.3"))
Being entirely unfamiliar with Mechanical specifically, your best best is to look at the ActiveX (COM) API Documentation (either VBA, or .NET)... So long as Mechanical supports that, many/most/all? of those Objects, Properties, and Methods will be available via LISP (generally speaking).
I already tried that but it gives me error
; error: Automation Error. Problem in loading application
Also documentation does not explain this. Once I can get hold of the symb object, then VBA documentation can help.
This is an example of adding a civ3d point it should be similar for Mechanical open database then open subset and add. The hardest thing is finding variable names for gets & puts. Google a fair bit and gradually it comes together. In this example we add points you can have surfaces, alignments etc A few more variables available inI code would be ptnum and description. Use dumpit.lsp on existing object or code below
(Vl-load-com)
(setq e (entsel ))
(setq obj (vlax-ename->vla-object (car e)))
(vlax-dump-object obj T)
;; Change ProgID per Traget Civil 3D version
;; This code sample is meant for Civil 3D 2013
(setq aeccApp (vla-getinterfaceobject
(vlax-get-acad-object)
"AeccXUiLand.AeccApplication.10.0"
) ; 2013 is 10.0
(setq aeccDoc (vlax-get-property aeccApp "ActiveDocument"))
(setq oPoints (vlax-get-property aeccDoc "Points"))
(setq pt1 (vlax-3d-point '(10.0 10.0 1.0)))
(setq oPoint1 (vlax-invoke-method oPoints "Add" pt1))
  (vlax-put opoint1 'labelrotation 1.57) ;approx 90deg
(setq pt1 (vlax-3d-point '(20.0 10.0 2.0)))
(vlax-put opoint1 'labelrotation 3.14) ;approx 180deg
(setq pt1 (vlax-3d-point '(20.0 20.0 3.0)))
(vlax-put opoint1 'labelrotation 4.71) ;approx 270deg
Thank you BIGAL. But I have not come across equivalent of "AeccXUiLand.AeccApplication.10.0" for AutoCAD mechanical
How did you find this value? Is it documented somewhere?
