satishrajdev Posted February 20, 2013 Posted February 20, 2013 hi all, I am using LEE MAC's code for getting attribute value which is as follows :- (defun LM:vl-GetAttributeValue ( block tag ) (setq tag (strcase tag)) (vl-some (function (lambda ( attrib ) (if (eq tag (strcase (vla-get-Tagstring attrib))) (vla-get-TextString attrib) ) ) ) (vlax-invoke block 'GetAttributes) ) ) (defun c:test ( / ss ) (if (setq ss (ssget "_+.:E:S" '((0 . "INSERT") (66 . 1)))) (princ (LM:vl-GetAttributeValue (vlax-ename->vla-object (ssname ss 0)) (getstring "\nSpecify Tag String: ") ) ) ) (princ) ) (vl-load-com) But my prob is, I want to select multiple blocks at the time, please provide any solution for this Thank you Quote
pBe Posted February 20, 2013 Posted February 20, 2013 (defun c:test ( / ss tag i) (if (and (setq tag (getstring "\nSpecify Tag String: ")) (not (eq "" tag)) (setq ss (ssget '((0 . "INSERT") (66 . 1)))) ) (repeat (setq i (sslength ss)) (print (LM:vl-GetAttributeValue (vlax-ename->vla-object (ssname ss (setq i (1- i)))) tag ) ) ) ) (princ) ) Quote
satishrajdev Posted February 20, 2013 Author Posted February 20, 2013 Thankxxx a lot pBE..... Problem solved completely.... Quote
