ctdlc888 Posted February 20, 2013 Posted February 20, 2013 Hi experts, Need lisp to fast-connect points that are ALMOST horizontal or vertical aligned. It will ask for 1)pick first point 2) Go North, South, East or West 3) fuzz/tolerance distance left or right of direction. Illustration attached. Thank you Erratum: In the title, 'Fas' should be 'Fast'. Thanks ConnectLine.dwg Quote
marko_ribar Posted February 21, 2013 Posted February 21, 2013 You have duplicate points, so I did OVERKILL, and moreover your points are far away from WCS basepoint (0.0 0.0 0.0), so I moved all entities to be applicable for my code... It worked for me for fuzz factor : 1e-2... I'll attach my version of DWG... (defun c:fpgl nil (c:fillpointgridwithlines)) (defun c:fillpointgridwithlines ( / osm ape *error* fuzz ss k entpt pt ptlst ptcllst ptcl1 ptcl2 ptcl3 ptcl4 ) (setq osm (getvar 'osmode)) (setq ape (getvar 'aperture)) (setvar 'osmode 0) (setvar 'aperture 1) (defun *error* ( msg ) (if osm (setvar 'osmode osm)) (if ape (setvar 'aperture ape)) ) (prompt "\nSelect points for grid connection with lines") (while (not (setq ss (ssget '((0 . "POINT")))))) (initget 7) (setq fuzz (getreal "\nEnter fuzz factor (1e-1...1e-10) : ")) (setq k -1) (while (and (setq entpt (ssname ss (setq k (1+ k)))) (< k (sslength ss))) (setq pt (cdr (assoc 10 (entget entpt)))) (setq ptlst (cons pt ptlst)) ) (foreach pt ptlst (setq ptcl1 (nth 1 (setq ptcllst (vl-sort ptlst '(lambda ( a b ) (< (distance pt a) (distance pt b))))))) (setq ptcl2 (nth 2 ptcllst)) (setq ptcl3 (nth 3 ptcllst)) (setq ptcl4 (nth 4 ptcllst)) (if (or (equal (angle pt ptcl1) 0.0 fuzz) (equal (angle pt ptcl1) (* 0.5 pi) fuzz) (equal (angle pt ptcl1) pi fuzz) (equal (angle pt ptcl1) (* 1.5 pi) fuzz) (equal (angle pt ptcl1) (* 2.0 pi) fuzz)) (if (not (ssget (mapcar '/ (mapcar '+ pt ptcl1) '(2.0 2.0 2.0)) '((0 . "LINE")))) (entmake (list '(0 . "LINE") '(100 . "AcDbEntity") '(100 . "AcDbLine") (cons 10 pt) (cons 11 ptcl1))) ) ) (if (or (equal (angle pt ptcl2) 0.0 fuzz) (equal (angle pt ptcl2) (* 0.5 pi) fuzz) (equal (angle pt ptcl2) pi fuzz) (equal (angle pt ptcl2) (* 1.5 pi) fuzz) (equal (angle pt ptcl2) (* 2.0 pi) fuzz)) (if (not (ssget (mapcar '/ (mapcar '+ pt ptcl2) '(2.0 2.0 2.0)) '((0 . "LINE")))) (entmake (list '(0 . "LINE") '(100 . "AcDbEntity") '(100 . "AcDbLine") (cons 10 pt) (cons 11 ptcl2))) ) ) (if (or (equal (angle pt ptcl3) 0.0 fuzz) (equal (angle pt ptcl3) (* 0.5 pi) fuzz) (equal (angle pt ptcl3) pi fuzz) (equal (angle pt ptcl3) (* 1.5 pi) fuzz) (equal (angle pt ptcl3) (* 2.0 pi) fuzz)) (if (not (ssget (mapcar '/ (mapcar '+ pt ptcl3) '(2.0 2.0 2.0)) '((0 . "LINE")))) (entmake (list '(0 . "LINE") '(100 . "AcDbEntity") '(100 . "AcDbLine") (cons 10 pt) (cons 11 ptcl3))) ) ) (if (or (equal (angle pt ptcl4) 0.0 fuzz) (equal (angle pt ptcl4) (* 0.5 pi) fuzz) (equal (angle pt ptcl4) pi fuzz) (equal (angle pt ptcl4) (* 1.5 pi) fuzz) (equal (angle pt ptcl4) (* 2.0 pi) fuzz)) (if (not (ssget (mapcar '/ (mapcar '+ pt ptcl4) '(2.0 2.0 2.0)) '((0 . "LINE")))) (entmake (list '(0 . "LINE") '(100 . "AcDbEntity") '(100 . "AcDbLine") (cons 10 pt) (cons 11 ptcl4))) ) ) ) (*error* nil) (princ) ) (prompt "\nInvoke c:fillpointgridwithlines with shortcut c:fpgl ; \"Type only\" Command: fpgl") (princ) M.R. ConnectLine-MR.dwg Quote
ctdlc888 Posted February 23, 2013 Author Posted February 23, 2013 Greetings. Marko it worked in my attached file even without moving entities, and relieved the prompts i suggested.Great Quote
