davecuster Posted February 21, 2013 Posted February 21, 2013 I have a client that only has sldprt files for his parts and Im wondering if someone with Solidworks can export them for me in any Autocad 2009 format...(iges, step, or even dwg, dxf) I just need to get them in to make some changes. any help is appreciated. Quote
JD Mather Posted February 21, 2013 Posted February 21, 2013 AutoCAD 2009 does not read iges or step. You can convert them yourself (assuming the sldprt files are from release earlier than 2013) using free Inventor Fusion. Download Fusion from http://labs.autodesk.com Quote
davecuster Posted February 21, 2013 Author Posted February 21, 2013 odd....Ive used the stepin and igesin command to import these files before....not sure what version Solidworks they are. Just need someone to export them for me. Quote
davecuster Posted February 21, 2013 Author Posted February 21, 2013 I have some files a client sent that I need export as any file I can open in Inventor or Autocad 2009 (step, iges, sat, dxf, dwg) I do not know what version of Solidwrks they were created in. Any help would be greatly appreciated. Quote
SLW210 Posted February 21, 2013 Posted February 21, 2013 I merged your threads. Please do not double post. JD has provided the answer, just download Inventor Fusion and convert them for yourself. Quote
JD Mather Posted February 21, 2013 Posted February 21, 2013 odd....Ive used the stepin and igesin command to import these files before....not sure what version Solidworks they are. You must have been using AutoCAD Mechanical or a very early version of AutoCAD. Those commands were removed from vanilla AutoCAD sometime around v2000 or 2000i. In addition to Fusion, AutoCAD 2013 will now read IGES and STEP and sldprt files. You might download a trial of AutoCAD 2013. (the process is a bit criptic though) Zip and attach the files here if you can't get them converted in Fusion. Quote
cadprops Posted 10 minutes ago Posted 10 minutes ago If you need to edit the design, a STEP or SAT into Inventor is still the practical path, and someone with SolidWorks can export that for you. You will get the shape, not the SolidWorks feature history. For a quick conversion of a supported .sldprt, CADProps (https://www.cadprops.com) can open the part in the browser and export STEP after you sign in, but only as exact STEP when the solid B-Rep actually reads. Otherwise you just get a mesh, which is a poor starting point for changes. Quote
