Reu
Feedback On Code That allows only 5 digit interger input.
Reu
Just experimenting with the 'while' function and looking for feedback as to the quality of my coding.
(defun c:test (/)
 (setq count 0)
 (setq 5dig (getint "\nEnter a 5 digit number: ")) ;_Enter a 5 digit number.
 (while
   (/= count 5)
    (setq 5dig (getint "\nTry again, please enter a 5 digit number: "))
    (setq strcount (itoa 5dig)) ;_Set a variable "strcount" to string from the interger from the variable "5dig"
    (setq count (strlen strcount) ;_Count the length of characters in the variable "strcount"
 (princ "\nYour are the Winner!")
Thanks
Share this post
Link to post
marko_ribar
Maybe this topic can help you...
Share this post
Link to post
fixo
Or something like this
(defun 5int(/ num)
(while (not (and (or (initget 1)
      (setq num (getint "\nEnter a digits: ")))
  (if (minusp num)
    (eq 6 (strlen (itoa num)))
    (eq 5 (strlen (itoa num)))))
 (princ "\nAllowed input 5 digits only..."))
     (if num num)
Share this post
Link to post
Lee Mac
  • The variable count is initialised at zero rather than the number of digits of the integer specified by the user; hence the user will be asked to 'try again' upon correctly entering a 5-digit number:
Enter a 5 digit number: 12345
Try again, please enter a 5 digit number: 12345
  • If the user enters a negative number, the program incorrectly validates the input:
Try again, please enter a 5 digit number: -1234
  • If the user presses Enter at the prompt, the program will error since the itoa function cannot accept a null argument.
; error: bad argument type: fixnump: nil
  • The user has no way to optionally exit the loop without pressing Esc to force an error.
  • You have not declared your local variables (also known as variable localisation); to understand why this is important, see my tutorial here.
  • 'You're' or 'you are' is spelt incorrectly:
(princ "\n[color=red]Your are[/color] the Winner!")
I would suggest the following:
(defun c:test ( / int )
   (while
       (and
               (initget 6)
               (setq int (getint "\nEnter a 5-digit number: "))
           (/= 5 (strlen (itoa int)))
       (princ "\nThat wasn't 5-digits.")
   (if int (princ "\nYou are the winner!"))
Now:
  • User is not prompted again if 5-digits are entered the first time:
Enter a 5-digit number: 12345
You are the winner!
  • User cannot enter a negative number:
Enter a 5-digit number: -1234
Value must be positive and nonzero.
  • If the user presses Enter at the prompt, the program exits cleanly without error:
Command: test
Command:
  • As shown above, the user can optionally exit the program cleanly by pressing Enter at the prompt, without being stuck in the loop or the program resulting in an error.
Share this post
Link to post
