samifox Posted February 23, 2013 Posted February 23, 2013 Hello How can i code autolisp script to toggle freeze/thaw specific layer? If x layer is frozen thaw it and vise versa Thanks Quote
Lee Mac Posted February 23, 2013 Posted February 23, 2013 Here is a simple example: (defun c:ftog ( / layer l ) (setq layer "0") ;; Layer to Freeze/Thaw (cond ( (= (strcase (getvar 'clayer)) (strcase layer)) (princ "\nCannot freeze the current layer.") ) ( (setq l (tblobjname "LAYER" layer)) (setq l (vlax-ename->vla-object l)) (vlax-put l 'freeze (~ (vlax-get l 'freeze))) ) ( (princ (strcat "\nLayer " layer " does not exist."))) ) (princ) ) (vl-load-com) (princ) Quote
samifox Posted February 23, 2013 Author Posted February 23, 2013 Awesome lee can u please explain (I'm a new dummy) Quote
Lee Mac Posted February 23, 2013 Posted February 23, 2013 Awesomelee can u please explain (I'm a new dummy) You're welcome. Which part of the code are you unsure of? Quote
samifox Posted February 23, 2013 Author Posted February 23, 2013 and Lee... i excecute your code.. when trying to toggle on i have to regen so the objects re-appear how can i regenerate in the code? Quote
Lee Mac Posted February 23, 2013 Posted February 23, 2013 all those starting with vlax The vlax-ename->vla-object function converts the LAYER entity to a VLA-Object which may then be manipulated using its ActiveX Properties & Methods, rather than manipulating the DXF Group codes of the LAYER entity. I am then manipulating the Freeze property of the VLA Layer Object using the undocumented vlax-get / vlax-put functions, since these functions return native AutoLISP data types, rather than the Visual LISP :vlax-true / :vlax-false symbols as returned by vlax-get-property or vla-get-freeze. As for the toggle itself, consider: _$ (~ 0) -1 _$ (~ -1) 0 Quote
samifox Posted February 23, 2013 Author Posted February 23, 2013 Thanks Lee I'm totally lst with your last paragraph Quote
samifox Posted April 28, 2015 Author Posted April 28, 2015 The vlax-ename->vla-object function converts the LAYER entity to a VLA-Object which may then be manipulated using its ActiveX Properties & Methods, rather than manipulating the DXF Group codes of the LAYER entity. As for the toggle itself, consider: _$ (~ 0) -1 _$ (~ -1) 0 what did you mean by that Lee ? Quote
