Offset x units and move the offseted objects to y layer
Hi
I want to compose autolisp to Offset x units and move the offseted objects to y layer.
Thanks
Shay
this thread is over my understanding as im totaly new to autolisp (but i do have expirience in other languages)
ive come across this code but i hardly understand it
i add comments wtih questions
(defun c:test (/ n ss p e); 1. what the switch / means?
(if
   (and (setq n (getdist "\n Specify the Offset Distance
:"));2.what the use of "and"
here?
(setq
          ss (ssget
"_+.:S:L" '((0 . "*POLYLINE,*LINE,CIRCLE,ELLIPSE")));3. select all
polys,line,circle,elipse andd  put them in ss
variable?
        (setq p (getpoint "\n
Specify point :"))
      (command "_.offset" n ss "_non" p
"");4.offset all shapes?
      (setq e
(entlast))
      (if (tblsearch "LAYER"
"cover");.5???
        (command
"_.chprop" e "" "_layer" "cover"
"");.6???
Thanks
S
1 set local variables so not left in meory (a b / c d e) a b stay as variables in memory
2 use and as a test for user input
3 select all objects
4 offest all objects
5 check layer cover exists if not make
6 make layer see 6
7 (princ) at end exit quitely get messages other wise on screen
8 ss selection set can be anything you like "mylist"
