wastewater Posted October 11, 2006 Posted October 11, 2006 I am looking for a lisp command that will autonumber blocks that have been inserted for a fabrication drawing. And that will maybe make a bill of materials. But just number the blocks would be a great help. Thanks Quote
Patrick_35 Posted October 11, 2006 Posted October 11, 2006 Hi I have this french lisp You link the first and the second attribut with the option "Croissant" After, you copy and with the link, you have a autonumber attribut @+ Latt.zip Quote
wastewater Posted October 11, 2006 Author Posted October 11, 2006 Well if I could read french it might work. sorry I have attached a dwg file of what I would like for the lisp file to do. maybe that will work. fab.dwg Quote
Patrick_35 Posted October 12, 2006 Posted October 12, 2006 Hi I've created in your drawing a block named "Bloc" with one attribut Load latt and copy this bloc and you see the autonumber. If you delete one, two or n block, the remaining number of the blocks change If you want to insert a number in the link, you can decide in which order with TATT You have more possibilities @+ fab.dwg Quote
wastewater Posted October 12, 2006 Author Posted October 12, 2006 That works but really isn't what I want. I am looking for something that will do the leaders to and maybe the bom. Quote
firsrate_caduser Posted October 12, 2006 Posted October 12, 2006 thanks patrick that lisp works just fine, but it would work better if it was written in english... thanks a lot!!!! Quote
firsrate_caduser Posted October 12, 2006 Posted October 12, 2006 Hello Wasterwater, for your request, maybe you can use Autocad Electrical 2006. thid version can automate BOMs with blocks attached to the BOM. well maybe that would help if you have can upgrade to to CADE 2006 or 2007. I hope this would help you because I am using this version and it does prety cool things. Quote
Patrick_35 Posted October 12, 2006 Posted October 12, 2006 I think to translate it, but the little of intêret which it seems succiter, I wonder whether that are worth the blow @+ Quote
gbrilli Posted June 24, 2008 Posted June 24, 2008 hi all... i'm from italy... i have tryed your program to number the block... but it doesen't work could u help me? give me step by step instruction how to use it... thx Gianluca Quote
gbrilli Posted June 24, 2008 Posted June 24, 2008 The Program That U Have Used Numbering Only The Txt File... Not The Block..... Quote
Attila The Gel Posted October 9, 2008 Posted October 9, 2008 If you don't mind, I translated the lisp a bit, Cause I use this much myself! thx for the lisp anyways Latt(eng).zip Quote
Attila The Gel Posted October 30, 2008 Posted October 30, 2008 It seams that when you undo (ctrl-Z) wile your LATT command is in progress. you can't continue the chain anymore and get a fatal error within a few clicks?? Quote
