maybe i am missing something simple. the below code works (to a point) i can insert the "grabm" block and then enter into the spline command. i can place as many points with the spline as i wish however i need to hit enter 3 times before i can place the text i want to. Below is the code and grabm block.
(defun c:gls ()
 (initerr)
 (setvar "cmdecho" 0)
(setvar "orthomode" 0)
 (command "-style" "notes" "romans.shx"
"4.5" ".85" "10" "n" "n" "n")
 (setvar "osmode" 512)
(command "-insert" "grabm" pause "1" "1" pause)
(command
"spline")
 (while (> (getvar "CMDACTIVE") 0) (command
pause))
 (setvar "osmode" 0)
 (command "dtext" pause
"0")
(reset)
(defun
initerr ()
 (setq oldortho (getvar "orthomode"))
 (setq
oldlayer (getvar "clayer"))
 (setq oldsnap (getvar "osmode"))
(setq oldSTYLE (getvar "TEXTSTYLE"))
 (setq echo (getvar
"cmdecho"))
 (setq temperr *error*)
 (setq *error*
trap)
(defun
trap (errmsg)
 (command nil nil nil)
 (if
(not
(member errmsg
 '("console break" "Function
Cancelled"))
   (princ
(strcat "\nError: " errmsg))
 (setvar "orthomode"
oldortho)
 (setvar "clayer" oldlayer)
 (setvar "osmode"
oldsnap)
 (setvar "textstyle" oldstyle)
 (setvar "cmdecho"
echo)
 (princ "\nError Resetting Enviroment ")
(terpri)
 (setq *error* temperr)
(defun
reset ()
 (setvar "osmode"
oldsnap)
 (setvar "cmdecho"
echo)
GRABM.dwg
Those 3 presses were required to end the points picking cycle, respectively to indicate that you want to fix the ends using default tangents. To get rid of those will need to resort to something that will analyze user's input (i.e. GRREAD) and act accordingly instead of passing control to the editor.
