samifox Posted February 27, 2013 Posted February 27, 2013 Hi Autocad 2010 (FULL) dont recognize DLINE is that possible? Quote
ReMark Posted February 27, 2013 Posted February 27, 2013 (edited) DLINE is an AutoCAD LT feature. Creates a double line using straight line segments and arcs. According to Ralph Grabowski (Tailoring AutoCAD - Lesson #20)... ...DLine command in AutoCAD Release 12 and 11, and LT. Edited February 27, 2013 by ReMark Quote
ReMark Posted February 27, 2013 Posted February 27, 2013 Hi Autocad 2010 (FULL) dont recognize DLINE is that possible? Not to my knowledge nor was it born out by a simple test I ran using AutoCAD 2010 (same version as you are using). Command: appload DLINE.LSP successfully loaded. Command: DLINE loaded. Command: dline Dline, Version 1.11, © 1990-1992 by Autodesk, Inc. Break/Caps/Dragline/Offset/Snap/Undo/Width/: I got this version off of CADTutor where it appeared in Michael's Corner #8 of August 2003. Under the topic "Quick and Easy Parallel Lines" at the very bottom of the section there is a link to download the routine. Quote
lesleys Posted February 27, 2013 Posted February 27, 2013 Not sure if it functions the same as you need but in the full version of autocad type MLINE that will give you parallel lines. I only have 2013 so can't check if it is in 2010 but I know it has been around for a while. Quote
ReMark Posted February 27, 2013 Posted February 27, 2013 As I recall MLine does not function like DLine. Quote
SLW210 Posted February 27, 2013 Posted February 27, 2013 DLINE is MUUUCHOOO better than MLINE. Dline.Lsp Quote
