Copy with basepoint and paste not working
Hello!
Can anybody help. Within drawing and between drawing copy with basepoint and paste is not working anymore. What seems to be the problem?
M
What version of AutoCAD was the drawing originally created with?
Don't know do be honest.
I'm using 2008 and drawing is probaly newer one.
Are you current with all AutoCAD 2008 updates/service packs?
That might be something you ought to do don't you think? There was only one service pack.
Is this a 2D or 3D drawing?
Are there a lot of annotative scales used in the drawing?
Does this happen only in this one drawing or in any drawing you are working in?
Are all layers ON and THAWED?
Have you checked to see if it pasted in an unexpected location?
Maybe you could explain more fully what you mean. What exactly is not working? Does the copy not show up at all, wrong position maybe, pasted onto an unexpected layer,...?
Also, are you trying to copy from or paste onto a Paper Space layout? There's sometimes an issue with that, but MS usually works fine if the DWG isn't corrupt.
  • 6 months later...
AEC objects can cause this... exporttoautocad to fix this.
In my case it was too many objects of the same dimension style...
For some reason when i changed half of the dimensions to another dim style, purged, it started working again...
And I ve never seen this to be the solution, or the problem, but here it was.
Edited by ibach
