SmD71nG
Ok I can not seem to find anyone else having this issue anywhere on the net.
I am currently setting up a sheet set within one file where the main layout out is an xref with desired information drawn over the xref. I will need to setup a total of 30 some sheets(tabs) with 3 viewports on each sheet(tab)
Here is the main issue. I go to plot an individual sheet(tab) and everything comes out fine. The xref is set to color Gray( #8 ) with a screen of 60% and my overlay drawings shows up as the desired darker lines. However when I got to do a batch plot (publish/using same plot settings as an individual plot for all tabs) the lines and title block come out fine but my xref does not show up on any of the sheets.
I have tried multiple printers and plotters and the same thing happens every time with this drawing. Anyone have an idea what I am doing wrong? the xref is on its own individual layer, nothing is set to "do not plot", nothing is on the defpoints layer. I am currently using AutoCAD MEP 2013.
If you need any more information just let me know. Someone please help, I don't want to get to the end and have to sit and plot 30+ sheet individually every time someone makes a large change.
Edited by SmD71nG
Share this post
Link to post
