james_james Posted March 4, 2013 Posted March 4, 2013 (edited) hello everyone, I have problem with installation Microstation on win 7. When I am running the prequisities script it gives error with PrerequisitiesGUI.hta file. Anybody know how to fix it? Here is screen with problem http://szacik.fm.interia.pl/error_micro.jpg Thanks for any advice Edited March 6, 2013 by james_james Quote
envisioncad Posted March 8, 2013 Posted March 8, 2013 Which version of MicroStation are you trying to install on Windows 7? V8 2004, XM, V8i SS1, SS2, SS3 Make sure the prerequisite pack is the correct version for the version of MicroStation you are trying to install. Here is a link that might help http://communities.bentley.com/products/microstation/w/microstation__wiki/4170.aspx Quote
Guest AARi Posted May 12, 2013 Posted May 12, 2013 (edited) It´s a Bentley MicroStation V8i 08.11.xx may be you are downloaded a win32 and your win7 runs under 64 bits... NOTE: There is a way to install 32bit soft into 64 O.S. . Place the installation in different folder , some appz allow it... Edited May 15, 2013 by AARi Quote
caddcop Posted May 15, 2013 Posted May 15, 2013 The image shows SELECTseries 3. I've installed many copies on Windows 7 - always as administrator. That should work. Quote
bella123 Posted October 11, 2013 Posted October 11, 2013 The following BE Community WIKI should be of assistance in remedying your problem with your Microstation installation error. http://communities.bentley.com/products/microstation/w/microstation__wiki/script-error-during-microstation-installation.aspx Quote
