I am confused (not for the first time).
I need to select all the text on a particular layer. In VBA I made my selection set as follows
Set mySelSet = ThisDrawing.SelectionSets.Add("TextOnLayer")
gpCode(0) = 8 'layer
gpCode(1) = 0 'item
groupCode = gpCode
dataValue(0) = frmExportFerrule.cmbLayer.Text  'layer name
dataValue(1) = "TEXT" 'item type
dataCode = dataValue
mySelSet.Select acSelectionSetAll, , , groupCode, dataCode
I am sure this is simple but I can't work out how to do this in VB.Net. I can select all the text in the drawing but I can't work out how to filter it again. Can somebody point me to some sample code that I can study please. I am sure I shouldn't have to iterate through the set (although I may do that soon).
Here's some info that might help you:
Specify a single selection criterion for a selection set
The following code prompts users to select objects to be included in a selection set, and
filters out all objects except for circles.
VB.NET
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
_
Public Sub FilterSelectionSet()
'' Get the current document editor
Dim acDocEd As Editor = Application.DocumentManager.MdiActiveDocument.Editor
'' Create a TypedValue array to define the filter criteria
Dim acTypValAr(0) As TypedValue
acTypValAr.SetValue(New TypedValue(DxfCode.Start, "CIRCLE"), 0)
'' Assign the filter criteria to a SelectionFilter object
Dim acSelFtr As SelectionFilter = New SelectionFilter(acTypValAr)
'' Request for objects to be selected in the drawing area
Dim acSSPrompt As PromptSelectionResult
acSSPrompt = acDocEd.GetSelection(acSelFtr)
'' If the prompt status is OK, objects were selected
If acSSPrompt.Status = PromptStatus.OK Then
Dim acSSet As SelectionSet = acSSPrompt.Value
Application.ShowAlertDialog("Number of objects selected: " & _
acSSet.Count.ToString())
Else
Application.ShowAlertDialog("Number of objects selected: 0")
End If
End Sub
Thanks Tyke but I am pretty much there already. I can select all the TEXT or all the MTEXT or all the objects on Layer0. What I can't find is how to select all the TEXT on Layer0.
I have
[size=2]
[/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myEd [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] Editor = DocumentManager.MdiActiveDocument.Editor
[/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myTVs(0) [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] TypedValue[/size]
[size=2]' comment out for different selection
[/size][size=2][color=#008000][size=2][color=#008000]'myTVs(0) = New TypedValue(DxfCode.Start, "TEXT")
[/color][/size][/color][/size][size=2]myTVs(0) = [/size][size=2][color=#0000ff][size=2][color=#0000ff]New[/color][/size][/color][/size][size=2] TypedValue(DxfCode.LayerName, [/size][size=2][color=#a31515][size=2][color=#a31515]"0"[/color][/size][/color][/size][size=2])
[/size][size=2][color=#008000][size=2][color=#008000]'myTVs(0) = New TypedValue(DxfCode.l .Start, "MTEXT")
[/color][/size][/color][/size][size=2][/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myFilter [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] [/size][size=2][color=#0000ff][size=2][color=#0000ff]New[/color][/size][/color][/size][size=2] SelectionFilter(myTVs)
[/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myPSR [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] PromptSelectionResult = myEd.SelectAll(myFilter)
[/size][size=2][color=#0000ff][size=2][color=#0000ff]If[/color][/size][/color][/size][size=2] myPSR.Status = PromptStatus.OK [/size][size=2][color=#0000ff][size=2][color=#0000ff]Then
[/color][/size][/color][/size][size=2][/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] mySS [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] SelectionSet = myPSR.Value
myForm.Label2.Text = mySS.Count
[/size][size=2][color=#0000ff][size=2][color=#0000ff]End[/color][/size][/color][/size][size=2] [/size][size=2][color=#0000ff][size=2][color=#0000ff]If
I have
[size=2]
You neglected the "AND", or "OR" Operator as needed; sample code copied from link mentioned above:
<CommandMethod("FilterForText")> _
Public Sub FilterForText()
 Dim acTypValAr(3) As TypedValue
 acTypValAr.SetValue(New TypedValue(DxfCode.Operator, "<or"), 0)
 acTypValAr.SetValue(New TypedValue(DxfCode.Start, "TEXT"), 1)
 acTypValAr.SetValue(New TypedValue(DxfCode.Start, "MTEXT"), 2)
 acTypValAr.SetValue(New TypedValue(DxfCode.Operator, "or>"), 3)
 Else
 End If
End Sub
I didn't neglect it, that was the bit I couldn't find.
Now to see if I can get this working before I am meant to give this drawing back....
:surrender: ... However you want to phrase it, Dave, is fine by me... Just trying to help a friend. :beer:
YAAAAAAY!
[size=2]
[/size][size=2][color=#008000][size=2][color=#008000]'Add bit about counting text on layer
[/color][/size][/color][/size][size=2][/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myEd [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] Editor = DocumentManager.MdiActiveDocument.Editor
[/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myTVs(3) [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] TypedValue
myTVs.SetValue([/size][size=2][color=#0000ff][size=2][color=#0000ff]New[/color][/size][/color][/size][size=2] TypedValue(DxfCode.Operator, [/size][size=2][color=#a31515][size=2][color=#a31515]"<AND"[/color][/size][/color][/size][size=2]), 0)
myTVs.SetValue([/size][size=2][color=#0000ff][size=2][color=#0000ff]New[/color][/size][/color][/size][size=2] TypedValue(DxfCode.Start, [/size][size=2][color=#a31515][size=2][color=#a31515]"TEXT"[/color][/size][/color][/size][size=2]), 1)
myTVs.SetValue([/size][size=2][color=#0000ff][size=2][color=#0000ff]New[/color][/size][/color][/size][size=2] TypedValue(DxfCode.LayerName, [/size][size=2][color=#a31515][size=2][color=#a31515]"0"[/color][/size][/color][/size][size=2]), 2)
myTVs.SetValue([/size][size=2][color=#0000ff][size=2][color=#0000ff]New[/color][/size][/color][/size][size=2] TypedValue(DxfCode.Operator, [/size][size=2][color=#a31515][size=2][color=#a31515]"AND>"[/color][/size][/color][/size][size=2]), 3)
Thanks BB, that's one hurdle over, several more to go......
You're welcome; I'm happy to help. :)
BTW - How'd you make out on this thread? Not sure if this is part of that same initiative, or not. :unsure:
WWEEEELLLL,
same initiative in that we have to go through PADRs (development review) every year and I said I NEED to look at migrating from VBA to VB.Net and please buy me this book. The book was bought at Christmas and in a month or two I have to show the results of my migration. I decided that the cloud routine that the former request covered would be impressive but have now decided to do something less impresive but one that I have a chance of completing! :rofl: In other words, that one has died for now but will be back.
Well, let us know how you get on... And remember to use these (as applicable):
   Try
       DocumentLock
           Transaction
               '' <-- do something
           Commit()
   Catch
   Finally
fixo, thanks for link. I'll have a look when I get time to register.
Tyke, I am looking to get an old VBA routine to work as a VB.Net one but I don't want to just convert it. Now seems to be a good time to try and learn the language (and tidy up my code). Unfortunately I only get a few hours at it at a time as some project managers expect their drawings back.
