What a long title. I am hopeing this is a simple problem and I have just overlooked the obvious. However, continuing from my other posts you know I am trudging my way through VB.Net with the help of Jerry Winters' book. All is good as far as it goes....
I am trying to rewrite a VBA routine of ours but while I have most of the component parts in place I can't find out how to stick it all together.
The routine....
I have a form with a combo box, a list, a label and a command button.
The combo box displays a list of the layers.
The list lists all the text entities on the selected layer.
The label displays the number of text entities on the selected layer.
The button exports the list to a text file.
(The text file is supplied to our panel builders to create heat shrink wire end markers.)
The combo box population is easy.
I haven't got the list population sorted but shouldn't be a problem using the selection set currently used for the label count (yesterday's problem - now sorted).
What I want to happen is that when the combo box is changed my list and label get updated. However the selection set is in my class definition and the combo box change is in the form class. I can't see a way of passing from the combo box changed event to a sub within the class. If I put the selection set sub in the form class it doesn't like the call to the Editor.
What have I missed out?
I believe this is what you're after, Dave:
Class Form1
   Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
       ComboBox1.SelectedIndex = 0
   End Sub
   Private Sub ComboBox1_SelectedIndexChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ComboBox1.SelectedIndexChanged
       Dim comboBox As ComboBox = CType(sender, ComboBox)
       Label1.Text = CType(comboBox.SelectedItem, String)
   End Sub
End Class
Hard to tell, especially without code... Could you post a snippet? It sounds like you're experiencing a permission issue, but again, not sure what you're attempting to do within the non-Form Class. More information is needed.
Thanks BB. Yet again I will have to leave this for a while as real work and a half day off are going to prevent me looking at it. I will try and post the code after it has been tidied up. It has taken a bit of cut & paste today and needs recovering. :D
As always, you're welcome; I'm happy to help... As for the Cut+Pasting, 'surgery' is always painful, better now than later. :P
Enjoy your half-day. :)
That didn't take as long as expected. (Still not looked at yours thoguh).
My code...
This bit loads the combo box with the layer names and displays Form1
[size=2][color=#0000ff][size=2][color=#0000ff]Public[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Sub[/color][/size][/color][/size][size=2] ExportFerrules()[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] i [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Integer[/color][/size][/color][/size][size=2] = 1[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myForm [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]New[/color][/size][/color][/size][size=2] Form1[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myDB [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] Database = HostApplicationServices.WorkingDatabase[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]Using[/color][/size][/color][/size][size=2] myTrans [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] Transaction = myDB.TransactionManager.StartTransaction[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myLT [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] LayerTable = myDB.LayerTableId.GetObject(OpenMode.ForRead)[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]For[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Each[/color][/size][/color][/size][size=2] myOID [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] ObjectId [/size][size=2][color=#0000ff][size=2][color=#0000ff]In[/color][/size][/color][/size][size=2] myLT[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myLTR [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] LayerTableRecord = myOID.GetObject(OpenMode.ForRead)[/size]
[size=2]myForm.ComboBox1.Items.Add(myLTR.Name)[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]If[/color][/size][/color][/size][size=2] UCase(myLTR.Name) = [/size][size=2][color=#a31515][size=2][color=#a31515]"FERRULES"[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Then[/color][/size][/color][/size][size=2] i = myForm.ComboBox1.Items.Count[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]Next[/color][/size]
[/color][/size][size=2]myForm.ComboBox1.SelectedIndex = i - 1[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]End[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Using[/color][/size]
[/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] j [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Integer[/color][/size][/color][/size][size=2] = 0[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] LayNm [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]String[/color][/size][/color][/size][size=2] = myForm.ComboBox1.Items(i - 1)[/size]
[size=2][color=#008000][size=2][color=#008000]Call TextOnLayer(j, LayNm)[/color][/size]
[/color][/size][size=2]myForm.Label2.Text = j[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]Select[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Case[/color][/size][/color][/size][size=2] Application.ShowModalDialog(myForm)[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]Case[/color][/size][/color][/size][size=2] System.Windows.Forms.DialogResult.OK[/size]
[size=2]MsgBox([/size][size=2][color=#a31515][size=2][color=#a31515]"Hello"[/color][/size][/color][/size][size=2])[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]Case[/color][/size][/color][/size][size=2] System.Windows.Forms.DialogResult.Cancel[/size]
[size=2]MsgBox([/size][size=2][color=#a31515][size=2][color=#a31515]"Do Nothing."[/color][/size][/color][/size][size=2])[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]End[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Select[/color][/size]
[/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]End[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Sub[/color][/size]
[/color][/size]
This bit counts the number of text objects on the layer specified by the combo box.
[size=2][color=#0000ff][size=2][color=#0000ff]Public[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Sub[/color][/size][/color][/size][size=2] TextOnLayer([/size][size=2][color=#0000ff][size=2][color=#0000ff]ByRef[/color][/size][/color][/size][size=2] j, [/size][size=2][color=#0000ff][size=2][color=#0000ff]ByRef[/color][/size][/color][/size][size=2] LayNm)[/size]
[size=2][color=#008000][size=2][color=#008000]'Add bit about counting text on layer[/color][/size]
[/color][/size][size=2][color=#008000][size=2][color=#008000]'This has gone back in to the load stage for now.[/color][/size]
[/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myEd [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] Editor = DocumentManager.MdiActiveDocument.Editor[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myTVs(3) [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] TypedValue[/size]
[size=2]myTVs.SetValue([/size][size=2][color=#0000ff][size=2][color=#0000ff]New[/color][/size][/color][/size][size=2] TypedValue(DxfCode.Operator, [/size][size=2][color=#a31515][size=2][color=#a31515]"<AND"[/color][/size][/color][/size][size=2]), 0)[/size]
[size=2]myTVs.SetValue([/size][size=2][color=#0000ff][size=2][color=#0000ff]New[/color][/size][/color][/size][size=2] TypedValue(DxfCode.Start, [/size][size=2][color=#a31515][size=2][color=#a31515]"TEXT"[/color][/size][/color][/size][size=2]), 1)[/size]
[size=2]myTVs.SetValue([/size][size=2][color=#0000ff][size=2][color=#0000ff]New[/color][/size][/color][/size][size=2] TypedValue(DxfCode.LayerName, LayNm), 2)[/size]
[size=2]myTVs.SetValue([/size][size=2][color=#0000ff][size=2][color=#0000ff]New[/color][/size][/color][/size][size=2] TypedValue(DxfCode.Operator, [/size][size=2][color=#a31515][size=2][color=#a31515]"AND>"[/color][/size][/color][/size][size=2]), 3)[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myFilter [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]New[/color][/size][/color][/size][size=2] SelectionFilter(myTVs)[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myPSR [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] PromptSelectionResult = myEd.SelectAll(myFilter)[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]If[/color][/size][/color][/size][size=2] myPSR.Status = PromptStatus.OK [/size][size=2][color=#0000ff][size=2][color=#0000ff]Then[/color][/size]
[/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] mySS [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] SelectionSet = myPSR.Value[/size]
[size=2]j = mySS.Count[/size]
[size=2][color=#0000ff][size=2][color=#0000ff]End[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]If[/color][/size]
[size=2][color=#0000ff]End[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Class[/color][/size]
[/color][/size]
and this bit tells you that the combo box has a new selected layer
[size=2]
[/size][size=2][color=#0000ff][size=2][color=#0000ff]Private[/color][/size][/color][/size][size=2] [/size][size=2][color=#0000ff][size=2][color=#0000ff]Sub[/color][/size][/color][/size][size=2] ComboBox1_SelectedIndexChanged([/size][size=2][color=#0000ff][size=2][color=#0000ff]ByVal[/color][/size][/color][/size][size=2] sender [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] System.Object, [/size][size=2][color=#0000ff][size=2][color=#0000ff]ByVal[/color][/size][/color][/size][size=2] e [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] System.EventArgs) [/size][size=2][color=#0000ff][size=2][color=#0000ff]Handles[/color][/size][/color][/size][size=2] ComboBox1.SelectedIndexChanged
MsgBox(ComboBox1.SelectedItem)
[/size][size=2][color=#0000ff][size=2][color=#0000ff]End[/color][/size][/color][/size][size=2] [/size][size=2][color=#0000ff][size=2][color=#0000ff]Sub
what I was expecting to be able to do is call the "TextOnLayer" sub from the combo box "IndexChanged" code but they appear to be mutually exclusive.
I can get it to do what I want
but only by copying all the Imports from the Class.vb module to the Form1.vb module. Surely this isn't the right way to do it?
As I understand it, each Class file in your project/solution (i.e., .vb, .cs, etc.) requires the dependent Imports (using in C#) statement(s), in order to enable Type names to be reference without Namespace qualification.
thanks, I thought it might be simple. It just looks wrong.
Perhaps... But it (using Imports statement(s)) sure saves one an awful lot of typing when you're coding more than a 'hello world' equivalent. :thumbsup:
Compare this (with):
Namespace CADTutor.AutoCAD.PseudoCode.SampleWithImports
   Public Class Commands
       <[color="blue"]CommandMethod[/color]("WITH")> _
       Public Sub SampleWithImports()
           Dim doc As [color="blue"]Document[/color] =
               [color="blue"]Application.DocumentManager.MdiActiveDocument[/color]
           Dim ed As [color="blue"]Editor [/color]= doc.Editor
           ed.WriteMessage(vbLf & "** Bowties are cool ** " & vbLf)
       End Sub
       [color="green"]''<-- other CommandMethod methods[/color]
   End Class
End Namespace
... To this (without):
Namespace CADTutor.AutoCAD.PseudoCode.SampleWithoutImports
       <[color="red"]Autodesk.AutoCAD.Runtime.[/color][color="blue"]CommandMethod[/color]("WITHOUT")> _
       Public Sub SampleWithoutImports()
           Dim doc As [color="red"]Autodesk.AutoCAD.ApplicationServices.[/color][color="blue"]Document [/color]=
               [color="red"]Autodesk.AutoCAD.ApplicationServices.[/color][color="blue"]Application _
           Dim ed As [color="red"]Autodesk.AutoCAD.EditorInput.[/color][color="blue"]Editor [/color]= doc.Editor
       End Sub
   End Class
End Namespace
yes but the later one is more colourful
