Base map from google earth to autocad 2010
I want to prepare base map by google earth.
Please help me to prepare base map of Jeddah city only (Saudi Arabia)
It show clear view of all road name etc...
How can prepared base map of Jeddah City so that
it will use in our all autocad 2010 drawings
Thanks for your support and guidance
Regards
Mohd
Have you tried Google Earth Pro?
It might be of help
You could try GPS2CAD it has a free trial, Plex.Earth it has a free trial or just cut & paste from Google Earth/Map into AutoCAD.
I try copy past from google, but it image is not clear,
it is big image it picture discarded / not visible properly.
How can make correct / clear base map from google earth
which have to use in autocad drawing ?
Regards
If you read the previous posts carefully, you will see that three alternatives have been suggested. You will have to pay for them.
The basic Google Earth is downgraded to prevent getting something for nothing :(
As noted, both come with a free trial, not sure of any limitations on the trial, but at least you can try before you buy and if this is a one time thing, no money.
We have a person in another division that uses Map 3D, they ran the trial for Plex Earth and claimed it worked pretty good.
That software is dirt cheap compared to hiring an aerial photographer for high resolution imagery, I think my boss said our quote was for $12,000 US dollars. Which sounds like what you will need for high resolution of a vast area as you seem to want.
"There's no such thing as a free lunch!"
