fabriciorby Posted March 13, 2013 Posted March 13, 2013 I've made a circle and I would like to know how to get these 4 points. I'm almost sure that it's going to use angle stuff, for 90º, 180º, 270º and 360º. But I have no idea how to make this code work haha D: Can you guys help me? Quote
Tharwat Posted March 13, 2013 Posted March 13, 2013 Try this ... (defun c:Test (/ s e d lst) (if (and (setq s (car (entsel "\n Select circle :"))) (eq (cdr (assoc 0 (setq e (entget s)))) "CIRCLE") (setq d (cdr (assoc 40 e))) ) (foreach x (list 0. (* pi 0.5) pi (* pi 1.5)) (setq lst (cons (polar (cdr (assoc 10 e)) x d) lst)) ) ) lst ) Quote
Lee Mac Posted March 13, 2013 Posted March 13, 2013 Alternatively, (defun c:cpt ( / cn en rd ) (if (setq en (ssget "_+.:E:S" '((0 . "CIRCLE")))) (progn (setq en (entget (ssname en 0)) cn (cdr (assoc 10 en)) rd (cdr (assoc 40 en)) ) (mapcar '(lambda ( x ) (mapcar '+ cn x)) (list (list rd 0.0) (list 0.0 rd) (list (- rd) 0.0) (list 0.0 (- rd))) ) ) ) ) Quote
Tharwat Posted March 13, 2013 Posted March 13, 2013 Another . (defun c:Test (/ FindQuadrants s e) (defun FindQuadrants (e / d l) (setq d (cdr (assoc 40 e))) (mapcar (function (lambda (x) (setq l (vl-list* (polar (cdr (assoc 10 e)) x d) l)) ) ) (list 0. (* pi 0.5) pi (* pi 1.5)) ) l ) (if (and (setq s (car (entsel "\n Select circle :"))) (eq (cdr (assoc 0 (setq e (entget s)))) "CIRCLE") ) (FindQuadrants e) ) ) Quote
Stefan BMR Posted March 13, 2013 Posted March 13, 2013 And another (defun C:QPOINTS ( / e) (if (setq e (ssget ":E:S" '((0 . "CIRCLE")))) ((lambda (p e) (mapcar (function (lambda (x) (vlax-curve-getPointAtParam e (* pi x)) ) ) p ) ) '(0.0 0.5 1.0 1.5) (ssname e 0) ) ) ) Quote
fabriciorby Posted March 13, 2013 Author Posted March 13, 2013 (edited) Thank you guys One day I'm going to learn enough lisp stuff ): Is there a way to make this code prettier? (setq s (ssget "_+.:E:S" '((-4 . "<OR")(0 . "LWPOLYLINE")(0 . "CIRCLE")(-4 . "OR>")))) (setq tipo (cdr(assoc 0(entget(ssname s 0))))) (if (= "LWPOLYLINE" tipo) ................................ ) (if (= "CIRCLE" tipo) ................................ ) ) (defun LM:MAssoc ( key lst / item ) (if (setq item (assoc key lst)) (cons (cdr item) (LM:MAssoc key (cdr (member item lst)))) ) ) Where do you write your codes? When did you guys start learning lisp? Sorry, too many questions haha Edited March 13, 2013 by fabriciorby too many questions yet Quote
Tharwat Posted March 13, 2013 Posted March 13, 2013 This one works as well . (defun c:TesT (/ s e d i l) (vl-load-com) (if (and (setq s (car (entsel "\n Select circle :"))) (eq (cdr (assoc 0 (setq e (entget s)))) "CIRCLE") ) (progn (setq d (/ (* pi (* (cdr (assoc 40 e)) 2.)) 4.) i d ) (repeat 4 (setq l (vl-list* (vlax-curve-getpointatdist s i) l) i (+ i d) )) )) l ) Quote
Lee Mac Posted March 13, 2013 Posted March 13, 2013 Another: (defun c:cpts ( / cn en pt pl ) (if (setq en (ssget "_+.:E:S" '((0 . "CIRCLE")))) (progn (setq en (entget (ssname en 0)) cn (cdr (assoc 10 en)) pt (list (cdr (assoc 40 en)) 0.0) ) (repeat 4 (setq pt (list (cadr pt) (- (car pt))) pl (cons (mapcar '+ cn pt) pl) ) ) ) ) ) Quote
Lee Mac Posted March 13, 2013 Posted March 13, 2013 Is there a way to make this code prettier? I'm guessing you are looking for something like this: (defun c:myprogram ( / cen enx pnt sel ) (if (setq sel (ssget "_+.:E:S" '((0 . "LWPOLYLINE,CIRCLE")))) (if (= "LWPOLYLINE" (cdr (assoc 0 (setq enx (entget (ssname sel 0)))))) (while (setq pnt (assoc 10 enx)) (entmake (list '(0 . "POINT") pnt)) (setq enx (cdr (member pnt enx))) ) (progn (setq cen (cdr (assoc 10 enx)) pnt (list (cdr (assoc 40 enx)) 0.0) ) (repeat 4 (setq pnt (list (cadr pnt) (- (car pnt)))) (entmake (list '(0 . "POINT") (cons 10 (mapcar '+ cen pnt)))) ) ) ) ) (princ) ) PS: I'd prefer if you retained my function headers in future Quote
irneb Posted March 14, 2013 Posted March 14, 2013 Where do you write your codes?One of 2 places: ACad's VLIDE (just type VLIDE at the command prompt). Allows you to run your code directly inside acad together with debugging, you can also inspect other stuff or list all the lisp symbols, also has an Auto-Formatting function to rearrange code by placing new lines and indenting. Using a programmer's text editor (http://sixrevisions.com/tools/12-excellent-free-text-editors-for-coders/), normal Notepad and the like is a bit useless IMO. I use either Notepad++ or SciTE, but many others have similar capabilities. These usually have more tools for editing code like regex search & replace, folding, line numbering, indication of bracket levels, etc. The editor makes a big difference on figuring out what the code is doing and if you have a typo somewhere, e.g. with a decent editor you never need to count how many closing brackets are needed. When did you guys start learning lisp?I think most over here are from all walks of programming. Especially in Lisp you find many who have simply started because they needed something which made a task a bit easier / faster. All the way through to others who have actually been programmers before and now also do AutoLisp. It all depends on how much they want to achieve. Personally, I've started with AutoLisp in the late 80's by fiddling with it for myself. Well, actually my first intro into programming was at school playing about with GWBasic on an old IBM-PC, but I don't really count that since I was only playing about and only for a short while. Later I actually did a CS degree and "learned" to program (in other languages such as Pascal, C++, Java). Ever since then programming is something I simply do because I love to. I make a point of learning a "new" language whenever I can. You pick up new ideas the more you see how other languages go about certain tasks, making you able to do something in a different way in even one of the old languages - not necessarily better though. Though from all the languages I've learned, only lisp has given me so much bang for my buck. The others range from extremely complex to make a similar task, to being too simple to be of as much use. But no others have so much capabilities in such a simplistic arrangement as lisp has. Note here I'm referring to Lisp in the braoder sense - AutoLisp is only a dialect, which has been chopped to pieces omitting huge chunks of what true Lisp actually can do. Quote
fabriciorby Posted March 14, 2013 Author Posted March 14, 2013 That is interesting, Irneb (: Thank you for sharing! You must be a very expert coder haha I've tried VB.NET and Java some time ago. I didn't like coding so I stopped with everything. ): Nowadays I'm working with AutoCad and I got a lot of curiosity about AutoLisp and everything. Maybe I should try VB again. (: I'm using Notepad++ only, VLisp interface is not as friendly as it's useful. I'll learn how to use VLisp editor correctly... Is there a way to change the background color and the 'language' color too? Just like this: It would be very helpful haha Quote
Tharwat Posted March 14, 2013 Posted March 14, 2013 I'll learn how to use VLisp editor correctly... Is there a way to change the background color and the 'language' color too? Open the Notepad++ then go to Settings in menu and chose the second option which is Style Configurator and from the first popup list chose whatever you want to change and there are many more ... Enjoy it . Quote
fabriciorby Posted March 14, 2013 Author Posted March 14, 2013 Open the Notepad++ then go to Settings in menu and chose the second option which is Style Configurator and from the first popup list chose whatever you want to change and there are many more ... Enjoy it . But how to change it in VLisp Editor D: edit: I use the Deep Black theme in notepad++ Quote
Tharwat Posted March 14, 2013 Posted March 14, 2013 But how to change it in VLisp Editor D:I use the Deep Black theme I don't think that you can change the background in Vlide . What's wrong with the configuration of the Vlide ? is it not looks good ? Quote
fabriciorby Posted March 14, 2013 Author Posted March 14, 2013 I don't think that you can change the background in Vlide . What's wrong with the configuration of the Vlide ? is it not looks good ? Yeah, it doesn't. ): I tried to change but every time it closes it get back to the same thing, so sad. edit: White background for coding is not as good as a black one ): Quote
Tharwat Posted March 14, 2013 Posted March 14, 2013 Yeah, it doesn't. ): Not a problem , you'd get used to it in no time . Quote
fabriciorby Posted March 14, 2013 Author Posted March 14, 2013 Not a problem , you'd get used to it in no time . Dammit, white bg Quote
Lee Mac Posted March 14, 2013 Posted March 14, 2013 I don't think that you can change the background in Vlide. Yes you can, go to Tools > Window Attributes > Configure Current Quote
fabriciorby Posted March 14, 2013 Author Posted March 14, 2013 Yes you can, go to Tools > Window Attributes > Configure Current Thank you It's not that beautiful... But it works hahaha Any tip to put the line number just like Notepad++ does? Quote
Tharwat Posted March 15, 2013 Posted March 15, 2013 Yes you can, go to Tools > Window Attributes > Configure Current Unfortunately I can not change the Background because I have the Window Attributes dialog in my First version cad 2009 empty without any colour , but with the Cad 2013 is available completely , That's really odd . And I did change it in Cad 2013 and pasted the file in Cad 2009 and it is working normally Quote
