Face Based Family 'Always Vertical'
I'm really stuck this morning. I have downloaded a Revit file for a Thorn light fitting. The problem is the family is face based and I want to place it running on the sloped surface of a stairwell.
I can't find any way to do this. There is no tick box for 'always vertical' within a face based family.
I can't see any way to make it work plane based.
I can't export the geometry to a different type of family.
Stuck :(
I found a solution.
Create a new project with the family in it.
Link that project to your main project.
copy/monitor the family.
It will now be non-hosted.
So you're wanting a face-based family to be non-hosted?
A face-based family will host to any face you place it on. I have a guy that has complained because his jelly jar light accidentally hosted to some steel framing.
Check the original family for "Always Keep Vertical" and uncheck it.
I have a manufacturer created face based family there is no option for 'always keep vertical' meaning I couldn't place the family on a slope. That's why I had to go through the steps listed above.
...or tell us the manufacturer and part?
Creating another project just to dissociate a family from a plane is 100% the wrong way to utilize Revit.
