I have a lsp that works inserting blocks in the drawing.
To 'load' this blocks, I use to click and drag the .dwg file into the current drawing. By doing this I can import the blocks and layers too.
Is there a way to 'load' these blocks and layers using lisp?
2i4nK
Maybe a lisp to insert this .dwg in the current drawing?
Use the insert command with the full path of the drawing and you 'd have them all within the current drawing .
(command "_.-insert" "the full path of drawing" pause nil)
Thank you guys, GP_ and Tharwat! :D
and Lee too, of course haha
Sans lisp codes, Explore the power of Design Center[Ctrl+2] and Tool Palettes [Ctrl 3]
But with Tool Palette I can add one by one only, right?
While Design center is active, select your block library [folder[] right click and Create Tool Palette of blocks or even on a single file AND even on an open drawing. Try it and see if that works for you.
I get the full Palette but it doesn't load the blocks in the new drawing... :/
Of course not. The block tool palettes are there so you can have easy access to the blocks, its not physically on the drawing session but a link [pick at the ready]. It eliminates browsing for folder when using "insert".
Perhaps you are referring to Templates.
Options
File
Template setting
Default template File name ofr QNEW
Starting a new drawing with tons of Blocks all over the place doesn't appeal to me. Layers/Line-types/MleaderStyles on template is ok. I would suggest you play around with tool palettes and you will see its not just limited to Blocks. You'll be surprise how powerful that tool is.
HTH
Options
File
Template setting
HTH
haha, it's because I use almost all of these tons of blocks in the drawing.
I made a lisp that helps to insert blocks (position, rotation and stuff) but if someone run the lisp without the blocks loaded properly it gets an error.
So it's needed to 'load' all the blocks first.
I don't think template can help me in this case, I gonna check this on Monday.
Thank you :D
I made a lisp that helps to insert blocks (position, rotation and stuff) but if someone run the lisp without the blocks loaded properly it gets an error. So it's needed to 'load' all the blocks first.
If you ensure the necessary blocks reside in an AutoCAD Support Path (perhaps in a network support path common to all users), your program will be able to locate and insert the blocks when required (depending on how your program is written).
How to do that, hmmmmmmmmm
It seems to be a nice solution :D
How is your program creating the block references - INSERT command / entmake[x] / vla-insertblock?
Are the blocks in an AutoCAD Support Path?
Yes, the blocks are in an AutoCAD Support Path. But they are all in one big dwg :o
It's just
(command "_insert" "blockname" pt1 "" ang)
Run this in your 'big dwg' to export each block to a separate file:
(defun c:blk2dwg ( / def dir dwg )
   (setq dir (getvar 'dwgprefix))
   (while (setq def (tblnext "BLOCK" (null def)))
       (if (zerop (logand 125 (cdr (assoc 70 def))))
           (if (not (findfile (setq dwg (strcat dir (cdr (assoc 2 def)) ".dwg"))))
               (command "_.-wblock" dwg "=")
wtf :o
You're awesome! :D
Thank you, Lee
