reallylongnickname Posted March 17, 2013 Posted March 17, 2013 I found much info on creating 3D objects above X Y plane (which is Z), but I haven't been able to find info on creating objects on the underside of X Y plane (sub Z). I need to create objects above and below X Y. Please advise where to get info. thx. Quote
Organic Posted March 17, 2013 Posted March 17, 2013 You use the exact same method except instead of going up you go down. E.g. instead of extruding (+) 4m you extrude -4m [with regards to z = 0]. Quote
