Hi,
I have been goggling this for the last hour and can't figure it out.
I have been given a set of plans by a client to design a system on. The plans have a lot of layers and information on them that I don't need/want to merge to a base layer. If I click on anything on the plans everything gets select and is layer 0. I originally thought these were just poorly made plans but if I go through the layers in the toolbar and turn them off individually it works.
Its like somehow all the layers have been linked to layer 0 but are actually individual layers :?.
I'm guessing its a setting I don't know about, help!
are you able to select an individual item? If not you probably have a block that needs exploding.
As in click on individual items in the model? No when ever I click anything, everything gets selected. I'm not familiar with that?
That was it, thank you soooooo much! :D (I googled how to explode)
